Sasquatch - Render looks "smudged"
acocq_0801c2dc51acocq_0801c2dc51 Posts: 0
I have posed and rendered the Yeti LAMH preset that came with the Sasquatch product.
What I noticed is the "smudged" hair (especially around the head / face), where you no longer can distinguish any individual hair-structure, but rather just a grey smudge ...
Does anyone have any clue as to what is causing this ?
Are there any special render settings that have to be considered ?
Cheers,
Andreas
  • ReDaveReDave Posts: 815
    Lower the Shading Rate in the render settings.
  • acocq_0801c2dc51acocq_0801c2dc51 Posts: 0
    Well, that does help (sort of), but does not eliminate the problem.
    I even went ahead and tuned it down to 0.01, but still get "smudging" ... and to quote a good friend of mine:
    "That sucketh" :-/
    Any other ideas of what else might help ?
    I don't mind experimenting with various settings, but I'm lost because I do not understand the problem, only its symptoms.
    Cheers,
    Andreas
  • JaderailJaderail Posts: 0
    What are your pixel samples set to? They also play into how SHARP a image is.
  • RawArtRawArt Posts: 6,245
    What kind of lighting are you using?
    I know I have had issues with garibaldi and lamh hair under certain lights. You may want to look into the LAMH threads to see what the best lighting setup is. I know there was alot of discussion on that.
    Rawn
