New Bill Board Prop needs its own hard drive.
IvyIvy Posts: 7,165
I just bought this prop set and when I seen how big the downloads are I almost fainted.   there are 15 different downloads each about a 800MB or more each
So for anyone interested in this set I must warn you.  . you will need a 1tb hard drive just to down load the the complete set.  I took a screen shot of my my product library  I really doubt that I will be able to load this into my content directory because how much space it uses ..  Just Wow
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Thanks for the warning, I'll have to pass as it would take me weeks to d/l this with my crappy internet. I still have 3 products in my products list that I havent d/led due to a crazy large file size, so I really appreciate the info Ivy!
  • I think you're adding it up wrong. If we say each part is an average of 800mb, then x15 would be around 12gb in total.
  • IvyIvy Posts: 7,165
    The issue I have it it will need its own hard drive. I just don't have that kind of storeage space in my content folders , it would propely just take a couple of hours to download it all . But where the heck am I gunna put once I do..lol
    edited December 2017
    really then how would you add it up look at the product ibrary I posted  it shows each download size and there are 15 downloads so how would you add it up.. I have contacted the vender on advice on how to handle the download size
    Post edited by Ivy on
  • FishtalesFishtales Posts: 6,228
    Even taking them as all 1 GB in size only makes the total 15 GB.
    15 gigs in a content drive is huge for one product. do you think?
    really then how would you add it up look at the product ibrary I posted  it shows each download size and there are 15 downloads so how would you add it up.. I have contacted the vender on advice on how to held the download size
    A 1TB drive is 1024Gb. A couple of the files in the screenshot are 1Gb in size, the others are less. Even if they were all 1Gb that would still be just 15Gb. Still a hefty chunk of space for just one product though.
    that was my point. I already have 4 tb drives almost full of installed content. not including storage back up drives.   I am hoping the the downloads are cumulative and not stack up the mb's when you install them.  like I said I contacted the vender on some advice.
  • jag11jag11 Posts: 885
    Whatever the total, you need to multiply by 2, cause you need to download and then install.
  • SimonJMSimonJM Posts: 6,098
    And I to think I winced at the MCMMM texture/shader set of 3 x 400MB files .. ;)  I hope to hell that they never need to update the metadata!
    You can delete the installer, or place it on an off-line external drive. These are (fairly high-resolution by the look of it) images to be used as background elements so they are inevitably large - you could always install, back up to off-line media, and batch resize if you don't expect to need them at full resolution.
    Now you can imagine the shock I got when I opened the product library on this set...lol  I have your bill board props  they are only 300 mb thats managable.. this set not so much
    1609 x 902 - 231K
    Thanks to Riversoft   the solution .. is to put the content on a thumb drive. . Perfect. :)
