How to put caps on cylinders?
Thanks
Mic
Thanks
Mic
Ok I found out that they have to be put on, on creation.
Mic
This came up before, and because I still have the pics I thought I'd re-post the image, you never know someone might find it useful :)
There are a few ways you can close a hole, the screen grab I had stored shows two.
Thanks for the reply John
In a dedicated modeler should it not just be select the edges and have a fill command?
Its how itst done in Carrara
Mic
Yes, but when you as smoothing you will come into problems, also you have problems with Ngons. To be on the safe side I always aim for a face made up of 4 points.
After you set the height for the cylinder, click the "A" . The white highlighted ends will be capped. The "A" or close function is available in some other operations as well.
Thanks cdordoni
Yes... but only at creation
Mic
You still have the Close option in the Vertex Modeling tab. But as I stated earlier, you may have trouble with Ngons.
odd I created a cylinder in Hexagon beta to see for myself, I clicked the edge and it filled with an ngon immeadiately so I went to tools tab, vertex modelling and clicked quad tesselation and all was done
one annoying thing missing in Hexagon is a lathe tool, just thought I'd bring that up, had to make wine glass from a cylinder instead.
Extrude Line under Surface modeling is made to do that.
yes that extrudes it but lathe, a Carrara fuction I use a lot takes an edge and models a solid object around it in the polyline shape,
I see on Youtube 3D studio MAX also has this modifier
its great for making vessels of all shapes like weird bottles, bowls and chess pieces
I know I was frustrated not finding a similar tool in Blender which I am painfully trying to learn too.
I have not tried Carrara but I think DzFire is recommending the correct tool for the job. All it is doing is taking a profile and running a curve along it to make the object.
Here's a quick example, I don't normally do videos and I have not finished adding my short cuts hence me staring at the screen looking for the tools :)
Sorry no audio or subtitles, I can add the latter if you wish.
Hexagon has that as well. One of its earliest features.
And used in Amapi long before Hexagon.
it is a bit different, more steps but also it appears more options
I must try it
