How To Save Just the Head/Face as a SHAPE to the library?
Fauvist
in The Commons
In DAZ Studio I keep trying to save the face/head, but it makes me save the whole figure.
You need a separate head and body morph with just the head morph dialled into the base (non-morphed) figure. If it's for G8 you can use the headsplit dformer to create a separate head and body morph - if all you have is a single head and body morph combined together.
Thanks, I'll try it!
Here is a quick walkthrough on how to use it: https://direct.daz3d.com/forums/discussion/comment/2774606/#Comment_2774606
I've used it a few times to separate head and body morphs, it worked pretty good the few times I've used it.
If you need such, few month ago, in a related thread, I posted headsplit deformers for Genesis 2 & 3.
Save as shaping preset. From the popup dialog, unselect the figure and then only select actor -> head. You may have problems if you have certain full body morphs active. Like "Victoria 7". It's better to apply those morphs separately. E.g., "Victoria 7 head" and "Victoria 7 body".
