How To Save Just the Head/Face as a SHAPE to the library?
In DAZ Studio I keep trying to save the face/head, but it makes me save the whole figure.
  • 3Diva3Diva Posts: 12,058
    You need a separate head and body morph with just the head morph dialled into the base (non-morphed) figure. If it's for G8 you can use the headsplit dformer to create a separate head and body morph - if all you have is a single head and body morph combined together.
    554 x 349 - 36K
  • FauvistFauvist Posts: 2,290
    Thanks, I'll try it!
    Here is a quick walkthrough on how to use it: https://direct.daz3d.com/forums/discussion/comment/2774606/#Comment_2774606
    I've used it a few times to separate head and body morphs, it worked pretty good the few times I've used it.
  • EsemwyEsemwy Posts: 578
    If you need such, few month ago, in a related thread, I posted headsplit deformers for Genesis 2 & 3.
  • CMacksCMacks Posts: 202
    Save as shaping preset.  From the popup dialog, unselect the figure and then only select actor -> head.  You may have problems if you have certain full body morphs active.  Like "Victoria 7".  It's better to apply those morphs separately.  E.g.,  "Victoria 7 head" and "Victoria 7 body".
    where is this located at ? cause your image is cut off can not see it..
