I have an update to DS in DIM tonight ??
is there an update for DS 4.10 ? I loaded up DIM to do a few purchases from yesterday and today and it is in there for download ..300 meg+ file
  • DON'T INSTALL IT !
    It's being pushed out as a non BETA as well
    Is causing problems with hair colours and certain G8 characters, I've opened a ticket with support but seeing as it's the weekend it doesn't look like anybody is there.
    Not happy :-(
    S.
    Not happy :-(
    S.
    What problems are you having?
  • Problem with SC Chloe (and SC Karen) and also with Georgia hair colour in the viewport. The hair colour also affects the render. I'll attach examples files showing the issue.
    Re-installed Daz Studio and the affected content, no change. Would have liked to roll back to the previous version of Daz Studio but apparently you can't do that unless support send you the installation files.
    Other G8 content seems fine so far.
    S.
    481 x 760 - 50K
    452 x 490 - 30K
    383 x 495 - 27K
  • The BETA and STABLE version numbers are the same... Has something been pushed out that shouldn't have been...
    S.
  • mikael-aronssonmikael-aronsson Posts: 604
    edited December 2017
    There is nothing strange with that, when the beta testers are happy with the last beta it is released, it would be strange if the production release would be different from the last beta, that would mean they have added functionality/fixed bugs and not tested them wink
    Post edited by mikael-aronsson on
  • Both are dated 8th Dec...
    If the problem appears with only those products then the issue is with those products.  I installed 4.10.0.123 on sunday and noticed no difference with any of my content.
  • Possibly but they render fine so I suspected a viewport issue and I don't know how to contact the vendors on here. I opened a tech support ticket but have only received thier standard response so far.
    If nobody else is having trouble maybe its time for a full delete and re-install.
    S.
  • stephenschoonstephenschoon Posts: 365
    Anyway I've done further work on this and have uninstalled Daz Studio and all Daz content. Deleted the directories and Daz Studio registry entry and then re-installed. I did not delete DIM and the packages. After re-installing SC-Chloe shows the same issue and while originally I thought just hair using OOT hairblending (although I never use the hairblending) was affected I've now found it other hair is also affected. I have attached screenshots showing the issues I have seen.
    Regards
    Steve Schoon.
    801 x 842 - 97K
    880 x 786 - 64K
    906 x 791 - 79K
    1062 x 782 - 88K
    1238 x 870 - 151K
    924 x 709 - 122K
    Post edited by stephenschoon on
