General Freebie Requests
Adding to Cart…
I am looking for a Vapor Stick similar to those found at this link ..... www.myvaporstore.com/JOYE_eGo_C_Starter_Kits_Accessories_Joyetech_eGo_C_Elec_s/83.htm
You're not the only one Kerya, did multiple searches for a 3d model typerwriter and almost all were antique or something that looked like from the 80's.
Searching for freebie Dolphins, thanx :-)
Dolphins...
http://www.3dart.us/3d-models/animals/index.html
http://www.3dmodelfree.com/models/26530-0.htm
Turbo has several models you can search through...
http://www.turbosquid.com/Search/?keyword=dolphin&sort_column=A5&sort_order=asc
and if you're looking for cartoony...
http://www.sharecg.com/v/32262/
I'm not a gamer so can't be positive this is the type of controller you are looking for, you will find it near the bottom of the page...
http://lab108.x0.com/lab108/toys.html
no but thanks for trying though I am looking for a classic Nintendo Controller
I know I have seen more, just have to locate if they are still available.
This guy might let you use his model...
http://lwnoem.blogspot.ca/2012/10/nintendo-controller-3d-model.html
Same with this artist...
http://www.3dbuzz.com/forum/threads/182135-NES-Controller
Turbo has one and it's only $1
http://www.turbosquid.com/FullPreview/Index.cfm/ID/521942
I am normally at a loss when it comes to sketch up, perhaps you will have better luck...
http://sketchup.google.com/3dwarehouse/details?mid=d35f3e4b13fcc3f31f769745506a7c94
I own the dollar one and that was actually worse then the freebies, I contacted one of the two guys ay posted can't seem to find a way to contact the other, so we shall see thank you once again for the help! :)
IF you are a Poserworld member:
http://poserworld.com/Poser.Models/2012.and.Earlier.Models//10001/Collar.and.lead.for.the.Mil.dog.aspx
Another leash - not meant for dogs, so you will have to resize, but ...
http://www.philc.net/oola.htm
carrie did you have a preference on maker>
it would be simple to model if one knew what particular maker or design
also the 1 piece disposable, 2 piece rechargeable, or the older 3 part?
Thank you friend :-)
Thank you Kerya. I am a member of Poserworld. I can't believe I did not look there.
Simpleplanning , when you say maker ,I do like the e-Go ,and if a choice I'd like one like the e-Go C it is a 3 piece,battery,atomizer,and tank, but it could be just done as a one piece ,I mean I won't need to refill the e-juice ......:cheese: Thank you !!
I am looking for a free shader someone made some time ago and for the life of me can't find it. The shader was for fabrics and was done with cogs or gears or both. I though Age of Armour made it but was wrong. Anyone know where I can find it?
looking for a mustache kinda like the one in the pic, free preferred but willing to pay too
The only free moustache I know of
http://www.most-digital-creations.com/free_poser_poses_textures_morphs_props_42.htm
There's a freebie Morphin' Moustache at http://www.empken.com/downloads/downloads1.html#Free_Props (You'll have to scroll down a bit.) Note that it's for Michael 1, so it'll need a bit of tweaking to fit Michael 4 or Genesis...
Anyone know of a freebie Kataginu kamishimo set that's Genesis compatible? The Daz store has a paid for one for M3, but nothing for Genesis or M4. The Way of the Samurai set uses a Happi, not a kataginu.
Is there a leisure suit out there for M4, or at least enough to fake it for a head-and-shoulders portrait shot? It doesn't have to match the one worn by the title character of the "Leisure Suit Larry" games, but it should be reminiscent of that outfit... preferably with a bit better style.
(Yes, I know - the style can't get any worse... This wasn't my choice of outfit.)
I'm interested to see if anyone might be doing a fully articulated model for DAZ Studio or Poser of the Bubbleship form Oblivion. This would be really cool to put in some renders, although there could be some copyright issues that would come into play. Perhaps a slightly modified one with alternate textures and a different name would be better. :)
Someone wanted a moustache?
http://www.sharecg.com/v/63167/browse/11/Poser/Super-Stache
Rob, Do you have joequick's Nextwave jacket and Kobamax's M4S shirt for M4? Together they make a reasonable Leisure Suit Larry set.
I know joe doesn't have the jacket available and Kobamax was offering the shirt at Christmas but you are a man that has lots of freebies.
Also the shirt is Poser Dynamic but you can make it conforming and do you know how to change a Poser dynamic object to conforming in DAZ?
I know it not free; but Beowulf M4 is the closest I've seen.
And I already have Beowulf... I'll run that past the requester and see whether it's okay.
Does anybody know of any Poser or DAZ Studio format 40's or 50's style city architecture (or bridges, pillars, statues, radios, or other items I could potentially kitbash and retexture into NON-historically-accurate distant buildings or architectural elements?)
I already have Stonemason's Dystopia Furniture freebies from http://stefan-morrell.com/ bookmarked, those could probably be convered into buildings.
I found two collections of radios in a different format that might have worked great for buildings, but they imported badly with weird shaded polygons.
I can't seem to locate a single good example picture of the building style I'm trying to find (probably because I don't know the architectural style name to search for), but here's the design styles from that period in general for reference:
The style you're looking for is called "Art Deco". Alas, the only Deco radio I know of was in the collection at free.daz3d.com, which disappeared when we got the new forums...
EDIT: No, I spoke too soon. One Deco-style radio:
https://sites.google.com/site/mcasualsdazscripts2/mcjradio-prop
Some in sketchup fiormat. http://sketchup.google.com/3dwarehouse/search?tags=art+deco
It's a rather difficult era for Architecture, especially on this side of the pond, because it is an era that included the wartime period and the subsequent rebuilding afterwards, during a period of vast austerity and lack of resources.
A bridge (Noncommercial use only)
http://www.3dgurukul.com/Free Models/Poser models/Poser Interior/Poser Architecture.htm
House - but 1924
http://www.vanishingpoint.biz/freeitemdetail.asp?FreeItemID=503
Edited to add: if you are a Poserworld member
http://poserworld.com/Poser.Models/Building.and.Architectural/11735/1900.s.Style.Bank.Building.Model.aspx
3ds format
http://www.turbosquid.com/3d-models/free-facade-building-3d-model/519486
Villa
http://www.3dmodel777.com/Download-3d-model/Villa/Luxury-Villa.html
Maybe for background use
http://www.3dcadbrowser.com/download.aspx?3dmodel=1650
http://archive3d.net/?a=download&id=9970f43a
