Bundles not downloading properly
how do you install DAZ V 4 elite texture Amy CA V 4 Elite texture Lana CA V 4 elite texture Maya CA?
  • BeeMKayBeeMKay Posts: 7,019
    What download option are you using, DIM? Do yo get an error message?
    Also, V4 textures in DAZ Studio usually don't show up as Smart content, but you'll have to use the Content Library, where these tectures are usually in the Poser section, and unter "Poses", in some cases, also materials.
  • rk66rk66 Posts: 450
    I think CA = Carrara
  • SixDsSixDs Posts: 2,384
    edited November 2017
    rk66 is correct. If you are only using DAZ Studio, you only need to download the V4 Elite Texture: Amy and V4 Elite Texture: Amy StudioCF parts, using Amy as an example. The same for the other characters.
    If you are actually using Carrara, and downloaded using DIM, you probably need to ensure that your DAZ Studio content library is correctly included in your Carrara content sources..
    Post edited by SixDs on
