Clay/wireframe render in DAZ Studio
BubbleCloud
Hello!
(wow, this is my first post in here! :) )
Is there a way to make a clay (untextured) or wireframe render in DAZ Studio?
I'm still using DS 3, but if there's a way in 4.5 version, then it's ok, I'll do it there!
Thanks in advance.
Have a look here for wireframe rendering:
http://www.daz3d.com/forums/discussion/20826/
To do a clay render, set the Viewport to Smooth Shaded instead of Texture Shaded, it is the same in DS3 and DS4.
'Smooth shaded' doesn't seem to do the rick, I still get textured render.
(Maybe I should just remove textures manually? :) )
Thank you for your reply, I'll check that thread now!
The only way to get an untextured render is to remove all the textures.
Yes, you are right, Smooth Shaded only affects the viewport. If you do a Screen dump of the viewport you would be OK, but not a render.
Removing the textures should work though.
Thank you both, I just removed the textures and made my clay render! :)
