Clay/wireframe render in DAZ Studio
BubbleCloudBubbleCloud Posts: 58
Hello!
(wow, this is my first post in here! :) )
Is there a way to make a clay (untextured) or wireframe render in DAZ Studio?
I'm still using DS 3, but if there's a way in 4.5 version, then it's ok, I'll do it there!
Thanks in advance.
    Have a look here for wireframe rendering:
    http://www.daz3d.com/forums/discussion/20826/
    To do a clay render, set the Viewport to Smooth Shaded instead of Texture Shaded, it is the same in DS3 and DS4.
  • BubbleCloudBubbleCloud Posts: 58
    'Smooth shaded' doesn't seem to do the rick, I still get textured render.
    (Maybe I should just remove textures manually? :) )
    Thank you for your reply, I'll check that thread now!
  • BWSmanBWSman Posts: 0
    The only way to get an untextured render is to remove all the textures.
    Yes, you are right, Smooth Shaded only affects the viewport. If you do a Screen dump of the viewport you would be OK, but not a render.
    Removing the textures should work though.
    Thank you both, I just removed the textures and made my clay render! :)
