How do I make my Genesis 8 have metallic skin?
I've tried using tags in th Surface Editor section but they didn't work. Is there another way and what do I need to use to make her have metallic skin?
  • You could apply one of the metallics from the Iray Sample Shaders. Don't forget that you will need to render, or at least switch to the nVidia Iray preview mode, to see the result and that you will probably need something in the scene to reflect and/or some interesting light placements to get much benefit.
