Gregoria Hair
TabianTabian Posts: 76
Still having bother with Gregoria hair. I can not get the hair to accept the preset hair poses. I have tried it with the hair selected, the head and the neck but non of them seam to do the trick.
Any ideas what to do next please....
  • wancowwancow Posts: 2,708
    Try going through your content library. You should find it under My Library/People/Genesis/Hair/3DrMGenesisHair/GregoriaHairDS4/Styles/
  • Scott LivingstonScott Livingston Posts: 4,350
    For what it's worth, they should work when you have the hair selected. If I were you I might try reinstalling the product...I wonder if something went wrong with the installation.
    Also note that the GregoriaHair_M you have loaded in your screenshot is a mirror image, so any poses will apply mirrored also.
  • cwichuracwichura Posts: 1,042
    Do you have both the Genesis and Gen4 versions of the hair installed? If so, perhaps the presets you are trying to use from Smart Content are for the other version of the hair.
    Insert gripe here about how broken Smart Content still is, and how you're much better off just using the Content Library instead...
