Anatomical elements morph transfers
Hello all,
Is it possible to transfer G1 male's AE morphs to G2 male's. Has anyone tried and made a matching geometry prop? a script? a tut? Is the geometry too different?
thanks
    You can transfer g3 to g8 because they are essentially the same but I have not tried any of the earlier figure elements
    Like making transfers between body and head shapes in different genesis versions, you would need to make a clone of the gens that you want to transfer in the target gens.
  • j_stnkj_stnk Posts: 205
    Thanks,
    I've tried the clone route. the hip geometry is fairly different between g1 and g2 but all the rest is fairly the same. I may have thought someone worked around it some way. I wanted to transfer Wickeds 100 to g2 since they are detailed. I'm using Hexagon to make them but I thought I could take the easy route.
