Problem about teeth
Hi to everyone.
I needed to transfer the morph of a character from G3M to G8M, so I followed this tutorial:
https://sickleyield.deviantart.com/journal/Tutorial-Transferring-Character-Morphs-G1G2G3G8-409437916
It is very good, she has been very kind when I wrote to her to ask something and the model is almost perfect. Not even the eyes had some distortion.
But now I have just a little new problem.
As you can see in the pic, the teeth are... deformed? They look like rounded and smaller and I don't know what I should to do to fix this problem...
Can someone help me?
  • TheKDTheKD Posts: 2,711
    If I recall correctly, that happens when the mouth HD is dialed up when transferring a morph.
    And how I can fix it? O.o
    I mean, when I set the Resolution Level to base and SubDivision Level to 0 how I can do the same for the mouth?
    Or is there a dial HD for the mouth I didn't see?
  • The slider should be under Currently Used in the Parameters pane with the figure selected.
    thanks!
