DS4 FBX Export to Maya animation issue
mostlyhuman
I put a simple 5 frame animation on a Genesis 3 model, frame 1 is a neutral T pose and frame 5 is a custom pose. When I export through FBX to Maya I get a "Local Transform Changed" warning and the T pose is off in Maya and the skeleton is no longer aligned with the skin so when I move forward to frame 5 it causes skin stretching, the skeleton barely moves. I tried some different FBX export options and FBX versions but all had the same result. If I remove the animation either pose will export into Maya just fine with no issues. I have attached some screenshots for clarification. Thanks in advance for any help!
Post edited by mostlyhuman on
I'm having this problem too. Did you figure this out?
Please let me know
