DS4 FBX Export to Maya animation issue
mostlyhumanmostlyhuman Posts: 94
I put a simple 5 frame animation on a Genesis 3 model, frame 1 is a neutral T pose and frame 5 is a custom pose.  When I export through FBX to Maya I get a "Local Transform Changed" warning and the T pose is off in Maya and the skeleton is no longer aligned with the skin so when I move forward to frame 5 it causes skin stretching, the skeleton barely moves. I tried some different FBX export options and FBX versions but all had the same result.  If I remove the animation either pose will export into Maya just fine with no issues. I have attached some screenshots for clarification. Thanks in advance for any help!
1820 x 1631 - 273K
Post edited by mostlyhuman on
