Aiden seams problem
marblemarble Posts: 7,500
edited April 2013 in The Commons
Hi,
I've bought Aiden and started creating a character with him but a couple of spot renders shows a problem (see image attached). I've been having problems with seams showing for a while and have found advice here of setting the shading rate lower, etc. but I can't get this to go away.
I have an iMac 27" 2012 with NVIDIA GeForce GTX 680MX. I'll attach a shot of my settings too (I downloaded the AMR script to see if that would help set them correctly, but no luck).
Post edited by marble on
  • RenpatsuRenpatsu Posts: 828
    edited April 2013
    The rendering settings appear to be ok, but it looks like the surfaces may have different displacement and/or bump settings and perhaps cause seams to appear due that? Edit: also check UV mapping and such, as some UV map changes may not be that obvious in a render.
    Post edited by Renpatsu on
  • marblemarble Posts: 7,500
    I multi-selected all skin surfaces to set the bump. I have checked and all adjoining skin surfaces have the same settings.
    This is after a few minutes in Reality:
    908 x 469 - 434K
    Sorry - which UV mapping settings do I check? I tried changing from M5 to M4 but that messed it up completely.
    You were right the first time - sort of: I had the bump settings too high for the whole of the skin, not just for some parts. Dropping them down removed the lines in the spot render but also made the skin look like a plastic doll. I hope I can find a compromise.
    There is the other issue with the Reality render and the black lines where the seams are ,,, that does not appear to be bump related.
    edited April 2013
    I basically meant to double check whether the UV maps are all set correctly for the character surfaces. Sometimes I saw that some UV map switches are not necessarily obvious with huge grey areas (depending on body part).
    I don't got Aiden, so cannot check this particular character, my best guess is still either bump or displacement settings (including the maps), as when I look at the 3Delight render some areas certainly appear more bumpy than others. In the LuxRender it is less obvious. But perhaps someone else who got Aiden got a better idea.
    Edit: ah ok, perhaps have a look if something else is off there concerning bump/displacement, might be just that :) good luck
    This is a reality render with the bump turned down .. Still has those black seams.
    555 x 449 - 334K
  • scorpioscorpio Posts: 8,534
    That looks as if it could be the displacement map.
    edited April 2013
    I just updated LuxRender (from 1.2 to 1.2.1) and it has improved somewhat. The lines are still there but hardly visible. I'll have a play with the displacement settings but they are as they were "out-of-the-box" at the moment.
    796 x 663 - 506K
