Mouth control MS Lycan
Help! the character starts with its mouth open and there does not appear to be a way to input negative values, List of items included says there is a mouth close morph but it seems to be missing. How do I get the Lycan to close its mouth???
  • PuntomausPuntomaus Posts: 450
    The Lycan Close Eyes, Close Mouth and Snarl morphs are under Shaping - Head - Universal - SciFi
  • edited December 1969
    I looked for that path and it does not exist on my system. The only Lycan-close-mouth file on my system is a DSON support file which only opens another instance of DS4.5 it does not effect the MS-Lycan character that is already open.
  • Richard HaseltineRichard Haseltine Posts: 111,715
    That's not a file path, it's the location of the morph in the Parameters/Shaping pane.
  • Orion_UkOrion_Uk Posts: 231
    Lol, how funny I should stumble across this thread now..
    I was trying to find exactly the same thing last night, Thank you Puntomaus :)
  • edited April 2013
    Thank you for the information,
    The controls for this and several other products seem to me to be misplaced, can these controls be moved to a place that is in my mind where they belong without breaking DS4.5?
    Here is where it makes sense to me to locate a morph for this character
    1444 x 758 - 118K
    Post edited by broncomech_3c25f39046 on
    This location is not very intuitive and in my mind does not match the location provided by Puntomaus.
    I found it by opening in every tab I could find that had MSLycan in it
    1454 x 788 - 122K
  • Midnight_storiesMidnight_stories Posts: 4,112
    Wow that's an old one, it was my first go at a full genesis morph so I had no idea what I was doing had no Doc or rules to follow. However looking at where it is that where the QA wants that stuff put or it wouldn't pass. I agree it's way to hard to find if I knew how to use the wikipedia for it I would put it in to help. There quite a few of my genesis morphs with hidden gems.
    Can these morphs be copied to a different folder without causing problems with the character or DS4.5 operation?
    OK don't quote me on this I'm doing this off the top of my head where you see the morph dial you want to change Left click on the little clog wheel and select parameter setting then a dialog box come up there should be a path box there where you can change where it goes then go accept See pic one E.g. Next you need to save the morph again go to save as see pic2. Find the morph you just changed use the vendor name and product name and save see pic 3. I wouldn't advise doing this if you don't know what you're doing. Hope that's helps now I'm off to bed it's been a long day !!! zzzzzzzzzzzz
    470 x 931 - 132K
    670 x 715 - 122K
    1401 x 1037 - 328K
    Thank you for the help.
    Nicely done for having no idea what you were dong:-)
