Why do I have weird reflections in the eyes and how do I fix it?
dracorn
This is G8M in Iray. The only change I made is manually loading Iris and Scalara textures in Base and Translucency Color.
It didn't matter if I had a sky loaded or Boss Pro Light Set.
How do I fix this?
Post edited by dracorn on
Is it painted on the iris texture?
I have encountered that issue with some Twizted Metal G8F eyes: The reflections are part of the surface.
No the reflection is not painted on the texture.
I wasn't sure what happened, because it persisted when I loaded (normally) a new set of eyes. However, when I reloaded the full texture, the eye reflection returned to normal. When I manually added the new eye texture, the reflection was still normal.
PROBLEM SOLVED.
Thanks for your attention.
