v4 High Heel boots on Genesis???
MjetzerMjetzer Posts: 0
edited April 2013 in The Commons
After an hour of searching the forums I figured I asked. I just purchased Dark Rose and can't get the boots to fit. Tried everything I could think of. Dark rose is for V4 and I'm trying to fit to Genesis. This is the first item I've had that does conform decently.
Post edited by Mjetzer on
  • Richard HaseltineRichard Haseltine Posts: 108,441
    The shoes will have had a morph to fit the feet into them or will have required that the feet be hidden. The latter should work for Genesis too.
    Sometimes you can bend the boot's foot/toes back into the right pose when it's inappropriately conforming as in your latter pic. Try it in parameters with it conformed? This never would've worked with a cr2 but it seems to with TriAx from time to time.
  • deepred6502deepred6502 Posts: 393
    edited April 2013
    I had the same issue with Pretty3D's Black Pearl set.
    With opaque boots, often the best way is to hide the toes and feet. Not the most elegant solution, but still a good work-around. It's far more of an issue with sandals or open-toe shoes.
    Post edited by deepred6502 on
