v4 High Heel boots on Genesis???
MjetzerMjetzer Posts: 0
edited April 2013 in The Commons
After an hour of searching the forums I figured I asked. I just purchased Dark Rose and can't get the boots to fit. Tried everything I could think of. Dark rose is for V4 and I'm trying to fit to Genesis. This is the first item I've had that does conform decently.
756 x 752 - 59K
678 x 772 - 54K
Post edited by Mjetzer on
  • Richard HaseltineRichard Haseltine Posts: 111,779
    The shoes will have had a morph to fit the feet into them or will have required that the feet be hidden. The latter should work for Genesis too.
    Sometimes you can bend the boot's foot/toes back into the right pose when it's inappropriately conforming as in your latter pic. Try it in parameters with it conformed? This never would've worked with a cr2 but it seems to with TriAx from time to time.
  • deepred6502deepred6502 Posts: 448
    edited April 2013
    I had the same issue with Pretty3D's Black Pearl set.
    With opaque boots, often the best way is to hide the toes and feet. Not the most elegant solution, but still a good work-around. It's far more of an issue with sandals or open-toe shoes.
    Post edited by deepred6502 on
