[Solved] Error Message when loading G8F? Help Please.
3Diva3Diva Posts: 12,058
edited November 2017 in The Commons
I get a new error message when I load G8F:
Does anyone know how to fix it? I can't see a difference in G8F so I'm not sure what the file is supposed to be doing. It's definitely annoying to get the message every time I load G8F though and I'm thinking if it's a part of the base G8F it must have a purpose and be important. I tried uninstalling Genesis 8 Female Starter Essentials and redownloading them, but that didn't fix it. I also tried uninstalling Genesis 3 Female Starter Essentials and then redownloaded and reinstalled them as well but that didn't fix it either.
Does anyone know what the file does and/or how to fix it?
Post edited by 3Diva on
  • BeeMKayBeeMKay Posts: 7,019
    That looks like a wrong path... have you tried to track down the file? It might be there but in a different folder, named similar (maybe missing spaces or something like that).
    As quick fix, if you can track down the file, would be to recreate the path from the error message and put a duplicate of the file there.
    Post edited by BeeMKay on
  • 3Diva3Diva Posts: 12,058
    That worked! yes No more annoying message every time I load G8F! Thank you, BeeMKay!
    No problem. I use that quickfix with older content occasionally.
    It still would be a good idea to put in a support ticket and report the error message as well as the path where you found the bugger, so they can fix the problem. smiley
