Lots of crashes and glitches. No idea whats going on.
Angel
I'm having problems with Daz. When I use the Content Library Search Bar. It automaticly crashes. When I save as Support Asset. It automaticly crashes. When I export object files, the program crashes.
When I load Daz, half the time my content Library will gltich out, and go backwards instead of forwards and then my Library disappears. I have to exit the program to refresh the Library Tree.
I'm using Daz 4.1 but it was also doing this on 4.9... Anyone have an idea?
Post edited by Angel on
I assuem you mean 4.10, not 4.1? That sounds like an issue with file handling and/or the Content Management System (only the OBJ export issues would not be likely to be CMS-related). Have you in the past run DS (or DIM) as Admisitrator? That could store up permission issues for the future. Security software might also be an issue.
I think it was cause I didnt install the PostgreSQL CMS on this drive yet. I'm not seeing the error anymore. Thank you. :)
