Hierarchical Pose Editing - Tutorial
MattymanxMattymanx Posts: 6,998
edited October 2017 in Freebies
I did this up for someone else and thought I'd share.  Info pertains to Genesis 8 and 3 male and female.
To my knowledge, this is all correct.
I recommend using Notepad++ or simular to edit the files.
please remember to back up your files before editing.
*** Click image below for Full Size 1920 x 1080 ***
Post edited by Chohole on
  • mindsongmindsong Posts: 1,735
    appreciated!
    --ms
  • Eagle99Eagle99 Posts: 159
    Nice one! Thanks Matty!
    I recorded a macro in my editor (PSPad) to get rid of all "Translation" and "Scale" entries. So search for it (F3) and than run a recorded macro like up, Pos1, Shift, down, down.... , delete with F5 or so.
    Speeds up the whole thing a lot and might save you from overseeing one "," or ")", etc. .
    Kind regards,Eagle99
  • MattymanxMattymanx Posts: 6,998
    You're welcome Mindson, Eagle99
    Even though I had a different problem with a Hierarchical Pose Set (the poses were for a car and supposed to not work without that special car...) this tutorial/explanation worked greatly for me when editing the .duf files to make the poses standalone (so I can use them for other cars).
    In my case I had to remove all lines that had a ID and url line connected to the car(part/s), the ID line that parented the G8F to the car (by changing the "parent": "(car name)" part to "parent" : "") and then removing all the car-related entries in the "animations" part of the .duf.
    After that I could use the poses on a G8F and save them as normal poses, which I then can use with other car models after some slight adjusting.
