What to download?
Silvhe
Some time ago I bought the Ballerina Assembly kit. At the time, a year ago more or less, I downloaded just two files, an installer for the item and an installer for the metadata...
Today I reset the download to get the last updated version and I find 8 (eight!) :gulp: files in my downloadable products.
Well, it was a true update :-) Some of the files are labeled as "Mac" so I suppose I can skip them since I have a Windows system, but what about the others? I see:
- Ballerina Assembly Kit - Victoria 4 - PC
- Ballerina Assembly Kit - Poser Companion - PC
- Ballerina Assembly Kit - Legacy - PC
- Ballerina Assembly Kit - DSON Core - PC
I use the lastest DS 4.5 version, don't use Genesis (I need just the V4 part of the product) and occasionally I use the old 3.1.2.32 (for the camera pointer and a few other plugin that don't work on DS 4.5 anymore). Could please someone tell me what do I have to install? Do I have to remove the old files before installing the new ones? Thank you so much
You want the DSON Core. It stands for Daz Scene Object Notation, which basically means DUF files and the like, which is the format used by Daz Studio 4.5.
If you aren't using the Genesis version, you just want the V4 version.
Thank you guys, I installed just the Victoria4 file and that was all, it works both in DS3 and DS4. I only made a mistake letting DS4 read the metadata and had the files scattered along that absurd Content Library default structure, and had to go hunting the files to reorganize them in my library, but all went ok.
Thanks again :-)
