Looking for Josie K4
WolpiWolpi Posts: 323
edited October 2017 in The Commons
Is anybody out there who knows Josie for the Kids 4?
She was created by StephanieBT / Fisty and all I find of her in my Library doesn't work.
She came as setup-file so I have no control what was within and where to find it.
Would like to purchase her once more as folder pack but she's not there any more.
Don't mistake her with Josi
Post edited by Wolpi on
«1
  • glaseyeglaseye Posts: 1,312
    I guess only the 2 vendors can help you...
    Fisty appears to be somewhat active at sharecg still (at least a couple of months ago). Maybe you could try sending her a sitemail there.
    http://www.sharecg.com/pf/full_uploads.php?pf_user_name=fisty
  • MelanieLMelanieL Posts: 7,729
    edited October 2017
    Do you mean you can't find Josie in the store, or that you cannot find her in your runtime/content library? I believe she was removed from the store at some point.
    Fisty is still active in the store under the dual PA name: https://www.daz3d.com/fisty-darc and she is active in the forums - most recently I saw her posting in the thread about dForce in the Commons here: https://www.daz3d.com/forums/discussion/comment/2946351/#Comment_2946351 You could try PM-ing her from there.
    Post edited by MelanieL on
  • WolpiWolpi Posts: 323
    You asked the right question Melanie ;) I meant the store actually - even though Josie is already in my Library.
    The problem is: the maps are not applied to the figure. I thought some files were missing but now I wonder:
    Can it be their format isn't compatible with DS although it was offered bei DAZ?
    362 x 460 - 124K
    418 x 325 - 177K
  • vwranglervwrangler Posts: 4,972
    edited October 2017
    Just to be clear on the steps you're taking:
    You put a Kids 4 character/figure into the scene and use the materials from the Content Library (judging from your screen capture), but they don't show up in the workspace or on render. Is that correct?
    The materials are compatible with Studio; HSS -- Human Surface Shader -- is a Daz Studio-only format shader, so that wouldn't be your problem.
    Post edited by vwrangler on
  • fixmypcmikefixmypcmike Posts: 19,692
    What happens when you try to apply them?
    edited October 2017
    Yes, that's right! And this is the way I usually apply morphs and maps with success.
    Surprisingly I managed to contact Fisty and she answered promptly :)
    This is what I was told but I need it to be translated into simple words:
    "Being an older product from when Poser was still the standard there should be a Poser version of the file with all the textures, check your product library at Daz, under downloads you'll either have one file or two, if there's two you need both.  If you're using DIM make sure you have it configured to show Poser files, cause you can turn those off, and may be off by default in this day and age.  Also make sure if you did install both that they're installed to the same runtime, if you install the poser version to the runtime in the poser install folder and the mats are in the documents/daz3d/etc daz studio content folder the mats won't find the textures.  I haven't heard from StephanieBT for years, no idea what she's up to now.  Worst case if you can't find the Poser files contact Daz' customer service, they may have gotten lost off the Daz servers or something."
    As said it was a setup-version and all files were installed automatically. Good to know that the formats actually should work.
    ... the character turns grey all over then, Fixmypcmike
    but no error messages?
  • LeanaLeana Posts: 12,767
    Are you using iray to render? HSS is a 3DL shader.
    But of course! They are missing many basic files then.
    This is all what is in Josie's folder and where the previews lead to:
    (I'm going to compare it with other characters now ... )
    391 x 137 - 27K
    523 x 397 - 135K
    edited October 2017
    I still use 3Delight, Leana.
    My comparison showed that the INJ and REM files seem to be missing with Josie's files.
    It's no problem if the morphs lack. I'm previously interested in the mats.
    This is what happens if I try to apply them:
    257 x 45 - 8K
    558 x 503 - 87K
    257 x 45 - 7K
  • carrie58carrie58 Posts: 4,089
    Wolpi double check your "Texture" folder  for this : texture\StephanieBT\Josie\  see if the textures are there
    INJ/REM are for morphs, not textures
    In Poser the mat pose files are under runtime/libraries/pose/Josie
    edited October 2017
    yes I know, and this is the path and folder my screenshot above shows.
    Assumely further folders in other places of the library are required to apply the mats.
    Either the Josie setup-file lacks them or the path is wrong or missing.
    I don't like setup-items; would like to have Josie as folder-pack to see what's all inside.
    The search function brings no results with 'josie'
  • BeeMKayBeeMKay Posts: 7,019
    Wolpi, you also need the files in runtime\texture\StephanieBT\Josie\ - this is what causes the error messages, because the files actual texture are either missing, or their path is different from what the duf file tells it.
  • HavosHavos Posts: 5,583
    How are you installing this product? Daz Connect, DIM or manually? The relevant zip is called IM00010570-01_Josie.zip and the file should have a size of 41.5MB (43,553,696 bytes). If you have the same size file, then chances are you have the correct product, you just need to ensure that it has been installed correctly.
    edited October 2017
    The problem is: I can't find the file. Since long ago my files system is proper and systematical - but Josie came earlier. I think it was a setup file without visible folders. Or an incomplete pack from Idunnowhere and regrettably she doesn't seem to be available anymore.
    Now I hope that somewhen somebody finds her somewhere and tells me I may purchase her once more.
    Thank you all for your kind help!
    kiss
    I still have the older.exe file for the product.     I also have the olde readme
    File list
    : Footprint File For []
    : This is a commented line
    : WIN_OSX
    :  COMMON
    \Runtime\Libraries\Materials\Josie\!Josie MAT.mc6
    \Runtime\Libraries\Materials\Josie\Eyes Blue.mc6
    \Runtime\Libraries\Materials\Josie\Eyes Brown.mc6
    \Runtime\Libraries\Materials\Josie\Eyes Gray.mc6
    \Runtime\Libraries\Materials\Josie\Eyes Green.mc6
    \Runtime\Libraries\Morphs\Josie\hideJosieEyeL-lEye.pz2
    \Runtime\Libraries\Morphs\Josie\hideJosieEyeR-rEye.pz2
    \Runtime\Libraries\Morphs\Josie\hideJosieHead-head.pz2
    \Runtime\Libraries\Morphs\Josie\injJosieEyeL-lEye.pz2
    \Runtime\Libraries\Morphs\Josie\injJosieEyeR-rEye.pz2
    \Runtime\Libraries\Morphs\Josie\injJosieHead-head.pz2
    \Runtime\Libraries\Morphs\Josie\remJosieEyeL-lEye.pz2
    \Runtime\Libraries\Morphs\Josie\remJosieEyeR-rEye.pz2
    \Runtime\Libraries\Morphs\Josie\remJosieHead-head.pz2
    \Runtime\Libraries\Morphs\Josie\showJosieEyeL-lEye.pz2
    \Runtime\Libraries\Morphs\Josie\showJosieEyeR-rEye.pz2
    \Runtime\Libraries\Morphs\Josie\showJosieHead-head.pz2
    \Runtime\Libraries\Pose\Josie\!Josie Head INJ.pz2
    \Runtime\Libraries\Pose\Josie\!Josie Head REM.pz2
    \Runtime\Libraries\Pose\Josie\!Josie MAT.ds
    \Runtime\Libraries\Pose\Josie\!Josie MAT.dsa
    \Runtime\Libraries\Pose\Josie\!Josie MAT.pz2
    \Runtime\Libraries\Pose\Josie\Eyes Blue.ds
    \Runtime\Libraries\Pose\Josie\Eyes Blue.dsa
    \Runtime\Libraries\Pose\Josie\Eyes Blue.pz2
    \Runtime\Libraries\Pose\Josie\Eyes Brown.ds
    \Runtime\Libraries\Pose\Josie\Eyes Brown.dsa
    \Runtime\Libraries\Pose\Josie\Eyes Brown.pz2
    \Runtime\Libraries\Pose\Josie\Eyes Gray.ds
    \Runtime\Libraries\Pose\Josie\Eyes Gray.dsa
    \Runtime\Libraries\Pose\Josie\Eyes Gray.pz2
    \Runtime\Libraries\Pose\Josie\Eyes Green.ds
    \Runtime\Libraries\Pose\Josie\Eyes Green.dsa
    \Runtime\Libraries\Pose\Josie\Eyes Green.pz2
  • frank0314frank0314 Posts: 14,713
    You should see the files in your Poser format within DS
    Thank you Chohole. These files are missing in my runtime.
    I wonder why she's not available anymore
    Yeah we don't know case it's missing for us as well.
    edited October 2017
    Yes, funny thing, I stumbled over her previews so often but probably mistook her with Josi and Josie Teen in my library.
    I somehow enclosed her in my heart. and would like to give life to her.
    We will follow this up on Monday, in normal Daz working time    Have bookmarked this thread so I won't lose it
    heart
    kiss
    If you've bought her once, she should still be in your Product Library at the DAZ3D Store - go to https://www.daz3d.com/downloader/customer/files then type "Josie" in the Filter field and  hit "enter". The new format files should show up there, no need to buy her again.
  • TaozTaoz Posts: 10,262
    edited October 2017
    kiss
    Yes, she is in the library. Installs and works fine in DS. Here in Iray with the Anagenessis 2 shader.
    800 x 860 - 362K
    Post edited by Taoz on
    Is she in the library just as Josie?  Who is shown as the owner.  Is she a PA item or a DO?
    Is she in the library just as Josie?  is she a DO or a PA item?
    Just "Josie" yes. No vendor info on the library page, but I've attached the product page data I captured while it was still in the store.
    651 x 1068 - 218K
