iRay Render - Optimisation: Max Path Length ?
Seeking answer as to what this is about.  Is there a reference that can tell me about it, please ?
I note it is at default value = -1
When I change it to 1, my rendered figure turns out completely black.
  • y3kmany3kman Posts: 862
    Just keep it at -1 (default; unlimited light transport path). You can read about Iray max path length from Nvidia's documentation. If you really want to use this option, set it to at least 3.
  • FishtalesFishtales Posts: 6,224
    Setting it too low and eyes also wont render properly. I keep mine at 10 which seems to be a good setting for most renders.
  • I think 6 is the absolute minimum for Genesis 3 eyes - I haven't checked Genesis 8, which has a modified eye structure.
  • HavosHavos Posts: 5,633
    edited October 2017
    the main benefit of a value other than -1 is that in theory your render will go quicker. Clearly 1-5 are not a good option for any render with a person in it, but 8+ should look identical (or near to) a value of -1, but render quicker. You have to try it and see
    Post edited by Havos on
    I don't know how much it speeds up renders but it speeds up the removal of fireflies.
