can DS's bake texture, bake the lie make up on to skin ?
MistaraMistara Posts: 38,675
can DS bake texture, bake the lie make up on to skin and export as new texture?
mebbe even offset lie layer a smidge ?
some make ups arent blending with the skin, looks like overlays. too shiny
is there a way to blend the lie layer with the skin, then bake it to new texture?
a bit of transparency or add the skin's bump map to the lie make up layer?
tysmiley
    tysmiley
    You could just use an image editor, load the base map and the make-up layer, tweak, save under a new name. You can also get the combined .tif file that DS generates from the temp folder - that, I believe, is how the LIE Baker script works.
    LIE already bakes the textures and saves as a numbered .png file in to your temp folder.  Copy them from the temp to a known Runtime/Textures/ folder or sub folder, give them new sensable names and re-link them in the Surface pane.
    tysmiley
    is there a tutorial on the features of 4.9 LIE?
    i'm not familiar with what it can do.
