Visible in Simulation
2»
  • namffuaknamffuak Posts: 4,442
    And the clothing outfit works quite nicely as well :)
    True. But while its a bit more real-world useful, it doesn't lend itself as well to a simple before/after compare. But the simulation and fitting process is worth looking at, gang!
    th3Digit said:
    Lyoness said:
    th3Digit said:
    and inevitably  someone will do dynamic anatomical elements and softbody saggy fun bags and cannot share
    drippy people are pretty fun.
    how low can they go?
    Vicky swing em over her shoulders like a regimental soldier
    OW! I can't unthink that image.
  • BeeMKayBeeMKay Posts: 7,019
    edited October 2017
    Mmm... but it also means that at this point, you can't use the dynamics on all the clothes and things you have bought so far, because everything needs to be adapted. I knew there was a downside to this...
    EDIT: https://www.daz3d.com/forums/discussion/203081
    At least, you can go and adapt your items yourself, if you are adventurous... *head explodes from reading*
    Post edited by BeeMKay on
  • exstarsisexstarsis Posts: 2,128
    Aave says her clothes should work with minimal adjustments in the Announce thread.... I remember trying to make Hinata dress look nice in that other cloth simulator.
  • thd777thd777 Posts: 945
    The process is actually quite easy. Here is a quick test. I used the skirt from the "Pleated Outfit", added a dForce modifier, painted aquick weight map to keep the top area stiff and in place and simulated. No great work of art, but it worked and took all of 2 minutes.
    Off to play in more detail...
    Ciao
    TD
    310 x 512 - 128K
  • LyonessLyoness Posts: 1,639
    it's actually very easy to do the "conversions"
    I played around and converted most of Lilflame's stuff.  I didn't save anything though... but I learned a lot!!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,291
    yes works on one I modelled myself
    Okay, for idiots now, please... where do I find "add dForce Modifier" in my surface tab? I find the dForce Surface Adapter, but I'm at a loss where to find the add thingamanom...
    its in the simulation window in right hand striped corner right click
    Ahhhh!!!! heart
    See, that's why my brain's exploding over the simpleness of it all.... wink
    video of my modelled dress on G8F
