The Lost World (Missing Files)
https://www.daz3d.com/the-lost-world
And so, this product is missing files. I have a short list of materials and they have the wacky scroll and tab (that I think indicates Poser files)
I found this list which states The Lost World needs DIM to install.
https://www.daz3d.com/forums/search?Search="The+Lost+World"
I uninstalled and installed it several times using DIM (with Daz closed) and the file system is still sparse. In renders I get the OCean and beach plane, but no shader loads to shade the water or beach.
Arggghhhhh,,,
I tried a manual install and slid the runtime over myself. Still, only three choices.
The product says Several shaders and such, but how do I get this working?
All help is appreciated.
Post edited by Griffin Avid on
Oh, and I did try another install using the Internal Installer and still no additional files.
It removes the little "install me" icon, but no changes anywhere.
Update: I swapped shaders and kept it moving.
Using some sand/rock to replace the beach and the VOID dark matter to replace the water.
Nothing like losing the few hours you get per day battling a product.
At least now I have a plan to keep from doing this again.
The s croll icon indicates a Daz Studio format sidecar file - usually materials, but it can also be a script performing other actions. In this case, I suspect your issue is that there are cistom 3Delight materials and you are rendering in Iray.
Here's a user guide that will shed light on how to use the product in both Daz Studio and Poser.
http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/17481/17481_the-lost-world-miniguide.pdf
You know, I did read that PDF and it appeared to only explain help for Poser users.
Doesn't say much more than things I don't have a propblem with - and there's no mention of multiple material files- aside from what it says in the actual product pitch.
Material Presets:
"tool kit" And this is what's new and I have never seen such in any other product before.
You know, when you see something this stunning, one assumes iray. lol
Apparently, this is OLDER than I thought. I grabbed this - this past July.
Thanks for the help. I missed the most obvious thing. It's a 3Delight product. Well seen.
