noobie question about adding smoke
Toobis
in The Commons
I got this: https://www.daz3d.com/fire-and-smoke-for-daz-studio while I can add the smoke props I don't understand how to actually make them look like normal transparent ordinary looking grey smoke. It ends up looking like it does in the pic when I render with Iray obivously I am missing something very obvious to make it transparent like normal smoke. What am I doing wrong please? thx.
Render it with 3Delight
This was created for 3Delight, and the shader was specifically created for 3Delight. It doesn't work properly in Iray (really not at all).
You could try a workaround by converting the surface to Iray, and then apply the Glass Solid Frosted Clear shader from the Iray Ueber package, and play around with those settings a bit.
k gottit thanks.
