noobie question about adding smoke
I got this: https://www.daz3d.com/fire-and-smoke-for-daz-studio while I can add the smoke props I don't understand how to actually make them look like normal transparent ordinary looking grey smoke. It ends up looking like it does in the pic when I render with Iray obivously I am missing something very obvious to make it transparent like normal smoke. What am I doing wrong please? thx.
1920 x 1080 - 546K
  • You'll need to use iray shaders, assuming they exist.
  • FistyFisty Posts: 3,416
    Render it with 3Delight
  • BeeMKayBeeMKay Posts: 7,019
    This was created for 3Delight, and the shader was specifically created for 3Delight. It doesn't work properly in Iray (really not at all).
    You could try a workaround by converting the surface to Iray, and then apply the Glass Solid Frosted Clear shader from the Iray Ueber package, and play around with those settings a bit.
  • ToobisToobis Posts: 993
    k gottit thanks.
