Adding to Cart…
I haven't had a chance to test to say how good it works or not or how easy it is to use or not. Nor can I compare/contrast it to elefont which has also been suggested but I thought I'd mention it here for what it's worth in case anyone wanting to add 3D text to something might already have it.
Edit: Okay this probably won't work for anyone looking to turn into 3D a particular font. All it appears to be is two different object libraries. One with a set of capitalized 3D letters from the english alphabet as well as some things such as .corp for making building signs and the other object library is a set of 3D numbers and common symbols. If you are wanting to have 3D letters from a particular font then look into the suggestion Horo gave of Elefont. If you don't care about it being a particular font and just need 3D letters and numers then the item I mentioned above would work for you.
*** find out if you are running the correct version of Bryce! ***
Bryce 7.1 Pro - Help, About Bryce - a short video by David Brinnen
You can find the link on my website (see sig below). Goto Raytracing > Tools > Elefont. Thanks for mentioning it, LHD.
How to create+import realistic/sculpted HD terrains :
******Required software: Mudbox/any sculpting app. and World Machine 2
1. see http://www.youtube.com/watch?v=vkb9HX6FSZE (How to create Vector Displacement Maps for Mudbox)
2. save the displacement map as 16bit .tiff (Integer) from your sculpting application.
3. load it into the world machine , apply erosion ..etc, build the terraing.
4. save the Heighfield output map from World Machine in 512 or 1024 or 2048 rez in .tiff 16bit
5.Open Bryce, generate a random terrain , click on E to enter in terrain lab, set the terrain for 512 or 1024 or 2048 from the left side of the terrain image on those multi little squares , click on "Picture" and load the highfield map saved from world machine as .tiff format.
6. Done :lol:
Average time to do it at first time including the stamp ~ 4-6 hours.
GOOD TO KNOW
Might work with zbrush/sculptirs/modo/etc too if can save displacement maps.World Machine free version can work with terrains up to 512x512 resolution.Saving as vector displacement map to be used again as a stamp/stencil on a blank plane in mudbox is useful if you want to create a terrain with parts of the duplicated mountain/hill.
Displacement maps can not used to save properly NEGATIVE sculpting such as canyons,river deltas.Or at least i didn't found a way yet.However if you computer and Bryce can handle a very high poly terrain you can save the sculpted/textured terrain with stamp/stencil used with INVERTED function as an .obj.This will create canyons ,river deltas,etc.If your computer cant hadle a high poly sculpted canyon or river delta then you have to be creative/inventive and make a fake canyon from some vertical mountains or ,the last option is to sculpt negative terrain in Bryce-terrain editor.
maybe i missed something or im wrong, waiting for a reply from Bryce masters.
Saving the terrain from mudbox as obj (high poly) to make the things much easier to load the terrain obj in Bryce might cause a crash or when you use E to smooth the polygons(might be low RAM the cause).Recommended is to use only heighfield maps.
Five new tutorials by Horo.
Bryce 7.1 Pro tutorial - Make Fake HDRI part 1 - by Horo
Bryce 7.1 Pro tutorial - Make Fake HDRI part 2 - by Horo
Bryce 7.1 Pro tutorial - Make Fake HDRI part 3 - by Horo
Bryce 7.1 Pro tutorial - Methods for rendering with natural light - by Horo
Bryce 7.1 Pro tutorial - Magic Mirror - by Horo
Video tutorials for Bryce 7.1 Pro. 128... or there should be, I've not counted - to there are probably a few links missing... anyway, these as of the 27th July 2012
Bryce desert landscape - part 1 - a 15 minute tutorial in two parts by David Brinnen
Bryce desert landscape - part 2 - a 15 minute tutorial in two parts by David Brinnen
Bryce still life project - "capsules" - a 15 minute tutorial by David Brinnen
Bryce lake in a landscape - a 15 minute tutorial by David Brinnen
Bryce shoreline - a 15 minute tutorial by David Brinnen
Bryce DTE > terrain skyscraper - part 1 - a 15 minute tutorial by David Brinnen
Bryce DTE > terrain skyscraper - part 2 - a 15 minute tutorial by David Brinnen
Bryce Depth of Field effect - a 15 minute tutorial by David Brinnen
Bryce Depth of Field effect - for less powerful computers - a video tutorial by David Brinnen
Bryce 'Nuts and Bolts' - using Pan V and Pan H - a video tutorial by David Brinnen
Bryce Abstract 360 HDRI Specular effect - a 15 minute tutorial by David Brinnen
Bryce lighthouse "light beam" effect - a 15 minute tutorial by David Brinnen
Bryce red hot metal effect - a 15 minute tutorial by David Brinnen
Bryce "Nuts and Bolts" - HDRI lighting project - red dragon in a white box - part 1 - a video tutorial by David Brinnen
Bryce "Nuts and Bolts" - HDRI lighting project - red dragon in a white box - part 2 - a video tutorial by David Brinnen
Bryce (TA) True Ambiance still life render of a red dragon - a 15 minute tutorial by David Brinnen
Bryce 10 minute material project - leatherette - a tutorial by David Brinnen
Bryce 10 minute material project - red pearlescent paint - a tutorial by David Brinnen
Bryce 20 minute lighting project - upgrading lighting - a tutorial by David Brinnen
Bryce grass terrains - a 25 minute tutorial by David Brinnen
Bryce light gel underwater effect - a 15 minute tutorial by David Brinnen
Bryce "Nuts and Bolts" - object cubic and spherical mapping - a 30 minute tutorial by David Brinnen
Bryce "Nuts and Bolts" - radial lights - a 30 minute tutorial by David Brinnen
Bryce 10 minute material project - rainbow texture - a tutorial by David Brinnen
Bryce 10 minute material project - using the rainbow texture and scene converter - by David Brinnen
Bryce "Nuts and Bolts" - TA optimised radial lights - a 40 minute tutorial by David Brinnen
Getting a Little Green Man from DAZ Studio to Bryce - a 10 minute tutorial by David Brinnen
Rainbow Vicky effect - a 10 minute tutorial by David Brinnen
Streaming light or "God rays" effect - a 25 minute tutorial by David Brinnen
Bryce "Nuts and Bolts" - TA optimised radial lights advanced - a 15 minute tutorial by David Brinnen
Bryce 25 minute lighting project - upgrading advanced lighting - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - TA RGB response - a 15 minute tutorial by David Brinnen
Bryce 20 scene lighting project - Using IBL with boost light and TA gels - by David Brinnen
Bryce 5 minute scene - TA hue saturation shift trick - a tutorial by David Brinnen
Bryce 20 minute scene lighting project - the Xyzrgb Stanford Dragon - a tutorial by David Brinnen
Bryce 5 minute scene project - turn your Xyzrgb dragon scene into a Vicky scene - by David Brinnen
Bryce 5 minute project - put a label on a jar - a tutorial by David Brinnen
Bryce 20 minute experiment - TA generated caustics - a video by David Brinnen
Bryce 20 minute scene lighting project - TA caustics effect - a tutorial by David Brinnen
8 minute Wings3D project - two part box - a tutorial by David Brinnen
Bryce 30 minute project - using Spherical Mapper to remap from HDRI backdrop onto 2D surfaces - a video by David Brinnen
Bryce 5 minute project - rendering a simple grey scene - a tutorial by David Brinnen
Bryce 15 minute scene - underwater city effect - a tutorial by David Brinnen
Bryce 10 minute scene - underwater city effect - made even more underwatery - by David Brinnen
Bryce 25 minute lighting project - advanced underwater effects - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - material lab channels - an overview by David Brinnen
Using Photoshop or HDRShop to use Masks - Appendix to "making and using masks" - by Horo Wernli
Bryce 15 minute material project - optical illusion moving spots - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - masking and using masks - a 20 minute tutorial by David Brinnen
Bryce 10 minute skylab project - basic sunset effect - a tutorial by David Brinnen
Bryce 25 minute skylab project - adding volume clouds to basic sunset effect - by David Brinnen
Bryce 10 minute skylab project - sunset effect, with clouds and put in a scene - by David Brinnen
Bryce 15 minute lighting project - low pressure sodium lights on a foggy night - by David Brinnen
Bryce 25 minute scene project - wings3D to render to postworks - a video by David Brinnen
Bryce 10 minute project - Wings3D text to Bryce - a tutorial by David Brinnen
Bryce 25 minute scene - anisotropic reflection in a landscape - a tutorial by David Brinnen
Bryce 15 minute scene - using the Spherical Mapper to reduce render time - by David Brinnen
Bryce 10 minute animation project - Kaleidoscope effect - a tutorial by David Brinnen
Bryce 5 minute problem - how to prevent your boat from getting waterlogged? - by David Brinnen
Bryce undocumented feature - the sea foam Easter egg - by David Brinnen
Bryce 15 minute scene - nice light setup using premium rendering - a tutorial by David Brinnen
Bryce 30 minute project - curvature filtering and lighting setups - a tutorial by David Brinnen
Bryce 10 minute project - glowing light emitter object material - a tutorial by David Brinnen
10 minute Wings3D project - making something to import into Bryce - a tutorial by David Brinnen
Bryce 10 minute render project - combine two renders with a mask in PSP8 - by David Brinnen
4 minute Wings 3D project - a quick look at Shell Extrude - a tutorial by David Brinnen
Bryce 30 minute lighting project - obscure lighting experiment - a video by David Brinnen
Bryce 5 minute lighting project - how to set up "obscure" lighting - a tutorial by David Brinnen
Bryce 10 minute lighting project - converting a scene to obscure lighting - a tutorial by David Brinnen
Bryce 10 minute scene project - lighting Eireann.sg's Wings 3D cube - a tutorial by David Brinnen
Bryce 5 minute scene - obscure glows - a tutorial by David Brinnen
Bryce 15 minute scene project - how to set up multiple glowing objects - by David Brinnen
Bryce 15 minute lighting project - specular obscure lighting theory - a video by David Brinnen
Bryce 30 minute project - setting up DS skin textures - initial attempt - by David Brinnen
Bryce 10 minute project - setting up DS skin textures - continued - by David Brinnen
Bryce 5 minute project - setting up DS skin textures - continued to cel effect - by David Brinnen
Bryce 20 minute lighting project - another obscure lighting experiment - a video by David Brinnen
Bryce "Nuts and Bolts" - Render option Reflection Correction - a 10 minute tutorial by David Brinnen
Bryce 15 minute project - turning the rainbow material into a bright star effect - by David Brinnen
Bryce 20 minute effect project - Exotic use of DOF - a tutorial by David Brinnen
Bryce 5 minute scene project - random inkblot generator - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - setting up the default launch state - a tutorial by David Brinnen
Bryce 20 minute beginners project - simple landscape - a tutorial by David Brinnen
Bryce 20 minute project - building a Menger Sponge - a tutorial by David Brinnen
Bryce 10 minute project - building a Menger Sponge (part 2) - a tutorial by David Brinnen
Bryce 20 minute beginners project - simple still life - a tutorial by David Brinnen
Bryce 25 minute lighting project - use sky - a tutorial by David Brinnen
Bryce 10 minute lighting project - use sky appendix - a tutorial by David Brinnen
Bryce 10 minute lighting project - crepuscular rays - a tutorial by David Brinnen
Bryce 5 minute effect project - fluorescent electron edge - a tutorial by David Brinnen
Bryce "TCB" - obscure lighting - a five minute tutorial by David Brinnen
Bryce "Nuts and Bolts" - a useful copy and paste trick - a tutorial by David Brinnen
Bryce 10 minute material project - grey rock with some cracks - a tutorial by David Brinnen
Bryce 25 minutes on landscape lighting basics - working with legacy skies - by David Brinnen
Bryce 20 minute effect project - frost displacement experiment - a tutorial by David Brinnen
Bryce 15 minute scene - simple terrain under advanced lighting - a tutorial by David Brinnen
Bryce 10 minute scene project - abstract space HDRI backdrop - a tutorial by David Brinnen
Bryce 5 minute scene - recursive abstract HDRI backdrops - a tutorial by David Brinnen
Bryce 5 minute scene - recursive abstract HDRI backdrops 2 - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - a 5 minute video on obscure AA topics - by David Brinnen
Bryce "Nuts and Bolts" - breaking down lighting, diffuse, ambient, specular and... by David Brinnen
Bryce "Nuts and Bolts" - multi-replicate - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - multi-replicate 2 - a tutorial by David Brinnen
Bryce 10 minute scene - abstract glowing line effect - a tutorial by David Brinnen
Bryce 15 minute lighting project - variations for multi-replicate 2 - a tutorial by David Brinnen
Using the Ivy Generator - a tutorial by David Brinnen
Using the Ivy Generator 2 - using flip normals - wire sculpture effect - by David Brinnen
Bryce 25 minute talk - organisation and object selection - a tutorial by David Brinnen
Bryce 15 minute scene - quick and dirty photorealism - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - large address aware - a short video by David Brinnen
Bryce 10 minute talk - convert to mesh and mesh object export basics - a tutorial by David Brinnen
Bryce "Nuts and Bolts" - Lens Flare - a tutorial by David Brinnen
Bryce 10 minute scene - Woven Cube - a tutorial by David Brinnen
Bryce 25 minute scene - Woven Cube 2 - a tutorial by David Brinnen
Bryce "Nuts And Bolts" - Rendering Efficiency - a tutorial by David Brinnen
Bryce 7.1 Pro Experiments - Obscure Gel Lights - by David Brinnen
Bryce 7.1 Pro Experiments - Lighting Interiors - by David Brinnen
Bryce 7.1 Pro Experiments - Lighting Interiors 2 - by David Brinnen
Bryce 7.1 Pro Experiments - Lighting Interiors 3 - by David Brinnen
Bryce "Nuts and Bolts" - Maximum Ray Depth - a tutorial by David Brinnen
Bit of an advert for the EWL and a short tutorial combined - by David Brinnen
Bryce 7.1 Pro Advanced - rendering inside photographs - by David Brinnen
Bryce 7.1 Pro Advanced - converting procedural textures into image maps 1 - by David Brinnen
Bryce 7.1 Pro Advanced - converting procedural textures into image maps 2 - by David Brinnen
Bryce 7.1 Pro Advanced - converting procedural textures into image maps 3 - by David Brinnen
Bryce 7.1 Pro Experiments - Export a tree as a terrain mesh - by David Brinnen
Bryce 10 minute scene - Grass Tree Recipe - a tutorial by David Brinnen
Bryce 15 minute project - Blending HDRI and Render - a tutorial by David Brinnen
And another...
Bryce 7.1 Pro Experiments - Exporting a scene as a heightmap - by David Brinnen
Bryce 7.1 Pro Advanced - Curvature filtering fix for terrains - by David Brinnen
Bit of an advert for the Spherical Mapper and a short tutorial combined - by David Brinnen
Bryce 7.1 Pro Advanced - Setup for SM texture capture cubic - by David Brinnen
Bryce 7.1 Pro Advanced - Setup for SM texture capture cubic appendix - by David Brinnen
Bryce 7.1 Pro Advanced - Using the texture capture cubic setup example - by David Brinnen
Bryce 7.1 Pro Advanced - Using the texture capture cubic setup with SC - by David Brinnen
Bryce 10 minute project - put a photo in the sky and improve your lighting - by David Brinnen
Bryce 20 minute project - put a photo in the sky and improve your lighting 2 - by David Brinnen
Bryce Basics - Composition part 1: How big is that thing? - by David Brinnen
Bryce Basics - Composition part 2: Really how big is that thing? - by David Brinnen
Bryce Basics - Composition part 3: Is that thing big? - by David Brinnen
Bryce Basics - Composition part 4: Is that thing really big? - by David Brinnen
Bryce Basics - Composition part 4b: Another version why? - by David Brinnen
Bryce Made Easy - Star burst space cloud effect - by David Brinnen
Bryce 7.1 Pro Advanced - Blue glass Stanford Dragon - by David Brinnen
Bryce Made Easy - SFX spaceship thrust - by David Brinnen
Bryce Made Easy - Abstract recipe 1 - by David Brinnen
Bryce Experiments - Metallicity and Specular Halo - by David Brinnen
Bryce Made Easy - Abstract recipe 2 - by David Brinnen
Bryce Basics - Camera control an overview for beginners - by David Brinnen
Bryce Landscaping - The importance of lighting - by David Brinnen
Bryce Landscaping - The importance of lighting 2 - by David Brinnen
Bryce Landscaping - The importance of lighting 2b - by David Brinnen
Bryce Landscaping - The importance of lighting 3 - by David Brinnen
Bryce Landscaping - Geocrafting guide - by David Brinnen
Bryce Landscaping - Materials - by David Brinnen
Bryce Landscaping - Extracting Content and Building Libraries - by David Brinnen
New tutorial from Horo Bryce 7.1 Pro tutorial - Obscure Lighting for Indoors - by Horo
Another new tutorial from Horo Bryce 7.1 Pro tutorial - Saving and Exporting Bryce Trees - by Horo
100's of Bryce video tutorials organised...
And a new video from Horo,
Bryce 7.1 Pro tutorial - FOV as Compositional Tool - by Horo Wernli featuring many of his renders and also some very useful information that is suitable for anyone trying to compose a scene.
Also I will take this opportunity to point out I've spent many hours sorting through the 200 video's on my channel and putting the videos together into order, categories and then into playlists. This I hope will make life much easier for people to find tutorials to suit their current level of ability.
http://www.youtube.com/user/davidbrinnen
More new guides - these have also been assigned to playlists but here's a direct link in case they cover a topic you happen to be interested in.
This first batch relate to my Bryce to Octane export project.
Bryce to Octane - Island scene conversion - part 1 - by David Brinnen
Bryce to Octane - Island scene conversion - part 2 - by David Brinnen
Bryce to Octane - Island scene conversion - part 3 - by David Brinnen
Bryce to Octane - Island scene conversion - part 4 - by David Brinnen
Bryce to Octane - Island scene conversion - part 5 - by David Brinnen
Bryce scene export to Octane first documented render experiment
Bryce to Octane - Another Islands (two) scene conversion - by David Brinnen
Then onto more Bryce focused stuff.
Bryce "Nuts and Bolts" - Exporting and importing lattices part 1 - by David Brinnen
Bryce "Nuts and Bolts" - Exporting and importing lattices part 2 - by David Brinnen
Bryce "Nuts and Bolts" - Exporting and importing lattices part 3 - by David Brinnen
Spherical mapping scenes for backdrops and including 2d faces - by David Brinnen
Minecraft map export to Bryce - Using jMc2Obj - a video guide by David Brinnen
Minecraft map export to Bryce 2 - Using jMc2Obj - a video guide by David Brinnen
Bryce "Nuts and Bolts" - Embed specular highlights in a materal - by David Brinnen
Bryce Made Easy - Velvet bump recipe - by David Brinnen
Bryce 7.1 Pro Advanced - very high power ambient recipe - by David Brinnen
Bryce 7.1 Pro Advanced - high energy gel light and hue shift trick - by David Brinnen
Bryce "Nuts and Bolts" - Fixing holes in lattices - by David Brinnen
Bryce 7.1 Pro Experiments - Extreme diffuse response - by David Brinnen
Super metallic effect - making impossible materials - by David Brinnen
Wow, thanks everybody for these tutorials. The ones I have seen so far sure makes it easy to use Bryce. It is really appreciated. :)
More things to do with extreme settings.
Extreme materials - a specular neon effect via IBL - by David Brinnen
Extreme materials - a specular neon effect continued - by David Brinnen
Extreme materials - creating an abstract pattern with super reflection - by David Brinnen
Extreme materials - super reflection variation on the neon effect - by David Brinnen
Bryce "Nuts and Bolts" - reflectionless glass recipe - by David Brinnen
Bryce "Nuts and Bolts" - reflectionless glass recipe 2 - by David Brinnen
Bryce "Nuts and Bolts" - reflectionless glass recipe 3 - by David Brinnen
Extreme materials - creating an abstract pattern with super reflection 2 - by David Brinnen
Extreme materials - creating an abstract pattern with super reflection 3 - by David Brinnen
Bryce 7.1 Pro Advanced - using the DTE as a geometry synthesis tool - by David Brinnen
Exported to Octane for final rendering.
Model a simple gemstone shape in Wings 3D - by David Brinnen
Wings 3D project - wings things with loops - by David Brinnen
First off I want to thank and show my appreciation to all who produce tutorials especially the ones that are free and available for download, and looking at the above list David, and Horo
I am coming back to Bryce again after being frustrated and disillusioned and dragging my feet through mud trying to learn the programme, I am slowly going through the Bryce 7 Artist Guide (all 1328 pages) and getting as many tutorials as I can.
My problem is (and it may just be my problem) is that I learn better when I know what things do, why we use them, and what happens either good or bad when we use them, as apposed to watching someone say "lets do this and this, press this and Voila there we are"
I looked at the Bryce Mentoring DVD and its a little pricey but I will get it if it helps me with the particular process I am trying to learn.
I am looking for detailed explanations, examples and reasons why we use and what each menu item does in
Texture Mapping Mode
The DTE - The Blend Mode - The Filter Dialogue,
Basically the nuts and bolts
so, my question is,
Are there any in depth tutorials on the menu items ?
or
Are they on the Bryce Mentoring DVD?
Thanks in advance
Welcome back to Bryce. It is difficult to answer your question about in-depth tutorials on the menu items on the Mentoring DVD. There are some but may not be the ones you're looking for. I understand your mode of learning very well: the why is at least as important as the how.
Have a look at my website (see sig) and go to Bryce Documents. You will find a couple of things that may interest you. Under Mine PDF > Diverse you find a document that lists everything that's on that DVD. The sub-topic Material has a 84 page PDF summing up the 17 videos by David on the DTE. Under the Video link, you find also links to the video Transcripts which are sometimes quite elaborate and are more than just transcripts.
Thanks Horo, on my way there now
Couple of new tuts today.
Wings 3D project - wings things with loops 2 - by David Brinnen
Wings 3D project - wings things with loops 3 - by David Brinnen
ok I gave the Wings3D ring thing a try.
figuring out materials and the scene took a lot longer than making the doohickey.
Now that is very nice. Bit dark on my monitor... maybe I've not got it set right?
a tad dark on mine too, might not have the HDRI settings quite right
More for the list.
Wings 3D project - wings mobius cluster recipe - by David Brinnen
Wings 3D/Topmod project - double cross mobius - by David Brinnen
Wings 3D project - compact mobius pair - by David Brinnen
Wings 3D project - wrapped torus knot - by David Brinnen
Wings 3D project - twisted mobius cube interlocking shape thing* - by David Brinnen
Stylised renders - a brief overview and a bit of a tutorial - by David Brinnen
Bryce 7.1 Pro - Pencil Sketch Effect - by David Brinnen
Pencil Sketch - Adding Haze and Clouds - by Horo Wernli
Wings 3D project - another twisted looped cube thing - by David Brinnen
Wings 3D project - interlinked mobius loops another way or three - by David Brinnen
Wings 3D project - interlocking torus knots - by David Brinnen
Bryce 7.1 Pro Experiments - simulating SSS basics - by David Brinnen
Wings 3D project - chain link torus knots - by David Brinnen
Wings 3D project - interlocking mobius torus knot - by David Brinnen
Wings 3D project - 36 section chain link loop - by David Brinnen
Wings 3D project - 32 section twisted chain link loop - by David Brinnen
Wings 3D project - two part twisted woven cube - by David Brinnen
Wings 3D project - icosahedron twisted loop - by David Brinnen
Wings 3D, UV Mapper Classic and Bryce - colouring both sides of the helix - by David Brinnen
UV Mapper Classic and Bryce - parametric mapping and repeating images - by David Brinnen
Bryce Basics - Green sky and light - by David Brinnen
Bryce Advanced Topic - combining several heightmaps into one - by David Brinnen
Bryce Basics - Free content cloud over Big Sur - by David Brinnen
Funky Shapes and Metals - making the test shape - by David Brinnen
Funky Shapes and Metals - UVmapping the test shape - by David Brinnen
Bryce Basics - Desert Landscape lighting and materials explored - by David Brinnen
Advanced - using Bryce to process HDRI for use in other applications - by David Brinnen
Advanced - exporting objects from Bryce for use in other render software - by David Brinnen
Bryce "Nuts and Bolts" - metals, anisotropy and "super" metallicity - by David Brinnen
Bryce Made Easy - Glowing stars recipe for sunset - by David Brinnen
Advanced - using custom brushes in the terrain lab - by David Brinnen
Bryce 7.1 Pro Advanced - rendering glass part one - by David Brinnen
Bryce 7.1 Pro Advanced - convert a funky metal into a funky glass - by David Brinnen
Bryce 7.1 Pro Advanced - rendering glass part two - by David Brinnen
I've done numerous searches and I can't seem to find a tutorial: I need to know how to set up a repeating or looping motion within a longer Bryce animation, such as pulsating lights, rotating ceiling fan,etc.
There must be a simple way to do this, but I haven't found anything. Links?
Hi Murphisto,
Well I can't answer your question but... I know who would be able to. Oro, the poster of this thraed http://www.daz3d.com/forums/discussion/33295/ I suggest posting a question at the end here and seeing if you can capture the ear of the Bryce animation master.
Thanks David, will do. And thanks for all of your great tutorials as well! They've been of immense help over the years.
Fallen a bit behind on my updates. Here's some more tutorials for those that like that kind of thing. Some Bryce, some Wings 3D and even the odd bit of DS in there.
Bryce 7.1 Pro - world in a tunnel lens effect - by David Brinnen
Bryce 7.1 Pro - world in a tunnel lens effect two - by David Brinnen
Bryce Landscaping - geocrafting a canyon - by David Brinnen
Bryce Landscaping - lighting a canyon - by David Brinnen
Bryce Landscaping - lighting a canyon advanced - by David Brinnen
Bryce Landscaping - Adding sheer walls to the canyon - by David Brinnen
Bryce 7.1 Pro Experiments - Advanced Obscure Lighting Setup - by David Brinnen
Bryce "Nuts and Bolts" - Reflecting on HDRI example effect - by David Brinnen
Bryce "Nuts and Bolts" - Reflecting on HDRI example effect 2 - by David Brinnen
Bryce 7.1 Pro Advanced - Two minute remix of AOLS - by David Brinnen
Bryce 7.1 Pro - AOLS remix combined render setup - by David Brinnen
Bryce Basics - Using the material, object and sky&fog; libraries - by David Brinnen
Golden Lighting - Example scene 1 - by David Brinnen
Wings 3D project - simple armoured ball - by David Brinnen
Wings 3D project - simple armoured ball 2 - by David Brinnen
Wings 3D project - extracted organic cube twist - by David Brinnen
Wings 3D project - cube twisted ported loop drilled - by David Brinnen
Wings 3D project - Octahedron twisted ported loop - by David Brinnen
Wings 3D project - Octahedron twisted ported loop webbed - by David Brinnen
Wings 3D project - Twisted loop test on five perfect solids - by David Brinnen
Wings 3D project - Art Wade twisted loop test on five perfect solids - by David Brinnen
Wings 3D project - Another twisted loop shape - by David Brinnen
Bryce 10 minute scene - SFX hyper texture for shadowless HDRI - by David Brinnen
Quick conversion of SFX hyper texture for shadowless HDRI - by David Brinnen
Wings 3D project - twisted cube with scaffolding - by David Brinnen
Bryce 7.1 Pro Advanced - plasma lighting effect - by David Brinnen
Bryce "Nuts and Bolts" - Looking around and setting up a DAZ 3D gallery - by David Brinnen
Bryce "Nuts and Bolts" - Create a hyperlink for your DAZ 3D forum signature - by David Brinnen
Bryce 7.1 Pro - Snow on trees effect - by David Brinnen
Bryce "Nuts and Bolts" - Chrome material recipe - by David Brinnen
Bryce 7.1 Pro Advanced - TA image projecting hyper gel light - by David Brinnen
Bryce 7.1 Pro Advanced - TA image projecting hyper gel light improved - by David Brinnen
Bryce 7.1 Pro Advanced - TA image projecting hyper gel light improved modified - by David Brinnen
Bryce 7.1 Pro Hypertextures - promo video 1 - by David Brinnen
Hypertextures - advanced water experiment 1 - by David Brinnen
Hypertextures - advanced water experiment 2 - by David Brinnen
Wings 3D project - make a funky shape - by David Brinnen
Wings 3D project - single interlocking mobius strip - by David Brinnen
Hypertexture driven high contrast gel lit rendering - by David Brinnen
Wings 3D project - general recipe for single mobius web - by David Brinnen
Wings 3D project - bobbly torus knot strip - by David Brinnen
Wings 3D project - three strand torus knot - by David Brinnen
Hypertexture driven ambient reflection mapping - by David Brinnen
Hypertexture driven ambient reflection mapping and scattering - by David Brinnen
Hypertexture - posterization filter - by David Brinnen
Hypertexture on fuzzy effect - by David Brinnen
Bryce 7.1 Pro Advanced - rendering trees on a terrain - by David Brinnen
Bryce 7.1 Pro Advanced - SSS effect for mesh models - by David Brinnen
Supplementary video - Bump value and polarity tip - by David Brinnen
Wings 3D project - Barley Sugar Twist - by David Brinnen
Bryce Basics - Rendering overview - quality, modes and output - by David Brinnen
Bryce Basics - DS prop material conversions - by David Brinnen
Wings 3D project - torus twist - by David Brinnen
Bryce 7.1 Pro Easy - Spooky trees in Dan's fog - by David Brinnen
Bryce Landscaping - Roy's terrain challenge 1 - by David Brinnen
Bryce Basics - remixing Pro materials - by David Brinnen
Wings 3D project - little Ouroboros critter - by David Brinnen
Wings 3D project - twisted bent rod to single interlocking mobius - by David Brinnen
Wings 3D, UV Mapper Classic and DS - deforming a DS figure - by David Brinnen
Bryce Memory Shortage - and what you can do about it - by Horo Wernli *** Horo ***
Wings 3D - my first UV map - by David Brinnen
Wings 3D - my second UV map - by David Brinnen
Bryce "Nuts and Bolts" - render an unseen objects shadow - by David Brinnen
Wings 3D - glass bubble and bowl - by David Brinnen
Bryce 7.1 Pro Advanced - initial investigation into glass material rendering - by David Brinnen
Wings 3D - make a triply twist it (mobius space) - by David Brinnen
Wings 3D - glass of wine - by David BrinnenD
Wings 3D - add extra structure to a simple model - by David Brinnen
DS project - the door bone is connected to the hip bone - by David Brinnen
Wings 3D - UV mapping primer part 1 - by David Brinnen
Wings 3D - UV mapping primer part 2 - by David Brinnen
Wings 3D - UV mapping primer part 3 - by David Brinnen
Wings 3D - UV mapping primer part 4 - by David Brinnen
Wings 3D - UV mapping primer part 5 - by David Brinnen
Bryce "Nuts and Bolts" - dealing with high resolution terrains - by David Brinnen
Wings 3D - UV mapping a mobius strip - by David Brinnen
Bryce 7.1 Pro Advanced - setting up a curvature based terrain metarial - by David Brinnen
Bryce 7.1 Pro Advanced - use gel - by David Brinnen
Bryce "Nuts and Bolts" - sphere dome light - by David Brinnen
Bryce and DS - sphere fill light and Moon Gate - by David Brinnen
Bryce "Nuts and Bolts" - parallel lights - by David Brinnen
Bryce Basics - interrupted rendering - by David Brinnen
Bryce Basics - render to disc - by David Brinnen
You Tube 300 - what software I use - by David Brinnen
Bryce 7.1 Pro Advanced - create a tracking panorama - by David Brinnen
Bryce 7.1 Pro - putting more than one sun in the sky - by David Brinnen
Bryce Basics - adding a photo sky - by David Brinnen
Bryce quick scene project - space pyramid - by David Brinnen
Wings 3D - Klein bottle - by David Brinnen
And if you want some of the models I made/used in the UV mapping tutorials, here they are in Bryce obp format.
Hatchet https://www.dropbox.com/s/9ocklc9tsd44rzt/Hatchet1.obp
Manual https://www.dropbox.com/s/jv0qhyrj2g3q14x/Manual1.obp
Matchbox https://www.dropbox.com/s/9iybirh43cqjde5/Matchbox1.obp
Cold remedy box https://www.dropbox.com/s/gvc6snxvb5tr5td/My_box.obp
Radio https://www.dropbox.com/s/o2nq3zon9n14kdy/My_radio.obp
I found this to be quite informative about the Instancing Lab. It may not be as "complete" as the ones by Peter that David pointed to, but gives the basics quickly :
http://www.daz3d.com/forums/discussion/3381/
Thanks Rashad!
Thanks. I being looking for tutorials on line.
The website https://www.bryce-tutorials.info/ has been given a major overhaul and now includes even more resources links to tutorials and well, to be fair, I'm always falling behind on my updates so this is the solution to that issue. The site has a search feature now which should (in theory) make it easier to track down the specifc topic/tutorial you are looking for.
The site is awesome now very user-friendly. When I visited last week I thought I was in the wrong site but soon realized that site was revamped.
I agree with mermaid: wonderful site now!
