Carrara Non Photo Realistic Works
13132343637100
  • Bunyip02Bunyip02 Posts: 9,302
    Bunyip02 said:
    Vicky in Harpsburg
    Very nice!  I like this one more than the other, partly because it looks more like genuine NPR to me.
    Hello UB, glad you liked it. I'm still exploring the NPR genre - and when Philemo's GMIC plugin becomes available there will be even more exploration.
    edited October 2017
    Dragon attack.
    1600 x 1231 - 5M
    Post edited by Bunyip02 on
  • VyusurVyusur Posts: 2,235
    edited October 2017
    Anime-some girl in Carrara. NPR, no post work.
    1000 x 1500 - 1M
    Post edited by Vyusur on
  • HeadwaxHeadwax Posts: 10,517
    Bunyip02 said:
    head wax said:
    Friend recently had some beautiful pots with succulents stolen (he is a ceramacist and ace photographer)
    I have trouble with this M4 - when i try to scale any part of him only his head gets bigger or smaller - any clues? Hence I cant fix his bulging neck shoulder part
    Hello Headwax - hope the Phantom solves the case.
    As for his shoulder-neck muscle http://www.innerbody.com/image_musfov/musc28-new.html
    Does your M4 have the TrapsSize morph activated in the Parameters tab ?
    thanks Bunyip02 for the suggestion. When I try to change any shaping morph the only thing that changes is the head size - nothing else. So sliding that parameter just gives me a big or little head !
    Bunyip02 said:
    Dragon attack.
    wow, this one is glowing
    really impressive, especially considering there is no post work!
    edited November 2017
    Little Bo Peep job out of an  unpublished book
    Post edited by Headwax on
    Cute !!!!
    Hello Headwax, sliding that parameter for me adjusts that muscle and not the head, you could have some mixed up morphs. You might need to reinstall M4.
    head wax said:
    Bunyip02 said:
    Dragon attack.
    Thanks
    head wax said:
    Image may contain: 1 person, standing, flower and outdoor
    Love the composition of this one plus the ducks looking for a feed of bread.
    thanks Bunyip02, yes there is something askew, the usual M4's work fine, Not sure why this one doesnt, it's a phantom thing I guess
    Little Bo Peep all grown up.
    and ready for action by the look of it
    Image may contain: 1 person, outdoor
    Phantom: The Second Take
    The grain is from Carrara's sand filter plugi,
    I used a distant light first on 2000 lumens, then on 400 lumens. combined in post with Toon Pro render and also coverage render.
    I took it into Corel Paint and ran a sitress filter over it
    then tinted it blue in PS by adding a layer, filling it with blue and changing parameter to 'Colour'
    Nice effect. Could the intensity of the shadow be reduced, looks a tad over powering in the scene to me.
    edited October 2017
    Ogora the Orc.
    800 x 1040 - 2M
    Andrew, Bunyip, thank you a lot!
    Andrew, great dramatic effect here! The only thing that distracts me is his right foot turned in (imho).
    A very touching scene with watercolour lightness.
  • StezzaStezza Posts: 9,012
    top shelf stuff everyone  yes
    give yourselves an
    thanks Bunyip02, Veronica et Stezza.
    Bunyip02 - good point. I think that's how the origibal comics looked - not sure will check.
    Veronica - interesting observation - the dog's head is the thing that stands out for me as being wrong, have had some comments about his package too.
    Something I hadnt noticed!
    Bunyip02 said:
    Ogora the Orc.
    Bunyp, this style is fab - I'd like to see a children's book like this (style, but  maybe not ogre :) )
    edited October 2017
    head wax said:
    Bunyip02 said:
    Ogora the Orc.
    Thanks Headwax - style as follows.
    First of all render from Carrara run through Topaz Adjust for colour correction.
    Then Topazed image taken into FotoSketcher - settings used are Painting Watercolor 5
    Topazed image then run through Filter Forge Old Book Illustrator
    Finally in PSP, FotoSketcher image is used as base layer, with Filter Forge pasted as a transperancy layer set at about 50% transperancy.
    1825 x 1017 - 2M
    1371 x 908 - 1M
    1918 x 1043 - 2M
    Greetings Bunyip02,
    wow, thanks so much for the blow by blow!! That's very kind.
     I may have to fork out for the pro version of  Filter Forge so I can get bigger renders - I think it maxes at 3000 pixels?
    head wax said:
    Greetings Bunyip02,
    Your welcome for the blow by blow description, did it in case a few of the others might be following whats being done.
    Filter Forge Basic/Standard is 3000 x 3000 pixels maximum.
    Filter Forge Professional is 65000 x 65000 pixels maximum, bump and normal maps, and an unlimited number of CPU cores.
    thanks, will check it out if ithas unlimited cores !
    Thanks Vyusur
  • mindsongmindsong Posts: 1,757
    Bunyip02 said:
    head wax said:
    Greetings Bunyip02,
    thanks for the detail - just the basic workflow ideas (steps/layers) involved help broaden our ways of thinking about all of this. The result is wonderful.
    cheers,
    --ms
    edited October 2017
    1600 x 1200 - 5M
