High Sierra for Mac avilable at App Store now and Daz Studio loves it!
High Sierra is out and at the App Store just for you. Download and install aprox. 1 hour in total. Get it now and have fun! It is great to be out of the beta now. I have a couple of hundred apps and the only one that broke (and I was told by developer in advance that it would)was Drive Genius. Zero problems with anything else! Daz Studio works even faster on my Mac than it did before the new OS!
Greetings,
*sigh*
My laptop Mac is now TWO operating system versions behind. :-/
I love my 17" MacBook Pro, and I _really_ didn't want to get a 15", but...this isn't going to be sustainable.
Thanks for the info, though!
-- Morgan
I am looking forward to eventually trying it. At the moment it is not possiable because it is not supported on Hybrid drives that my imac has. I hope they can remedy this soon.
Greetings,
@gsm77 You most certainly can run Mac OS X High Sierra on a hybrid drive or plain hard drive, it just doesn't upgrade your file system to the new APFS. While APFS is a pretty big feature, it's not the only one in the new version, so it's probably worth updating if you can.
-- Morgan
Looks like I need to wait for a new driver from Nvidia before I can have a go.
Thanks i may now consider upgrading in the next week or so.
No thanks, this upgrade replaces your entire file system, so I'm not in any hurry to experiment without backing up data.
Might want to check the Apple Discussions, under Support, and High Sierra, at Apple.com. Seems pretty safe, but I did check with Alsoft, which makes DiskWarrior, which can really repair problems at which Apple's Disk Utility may fail. Alsoft says they have to prepare a whole new version because of the APS file system. But, supposedly, if you have, as do I, an SSD drive in your main Mac, that will be automatically converted to the new file system. Then, for backup drives, I have the standard spinning drives from La Cie. I was told that's not a problem, and that High Sierra can both read from and write to regular hard drives. (Just saying some of what's over at Apple's Discussions. I'm not insisting this is the absolute truth.)
Anyone who is going to upgrade, though, should have a full, complete backup on another HD. Also, a caveat I've sadly learned is true: The leading edge, the cutting edge, is often the bleeding edge. In other words, it may be safer for a bit to read about the new features in High Sierra, and wait until we get the 10.13.2 or 10.13.3 versions out, which will probably remove some of the bugs. For regular Sierra, I'm at 10.12.6. There are always some bugs that are later discovered. They can't possibly test out all the various versions of Macs and Mac OSs that exist.
Yeah, if I had external backup drives, I wouldn't want Sierra trying to convert those, or any other non-OS drives connected to the system. I don't think you would be able to read them from Windows OS-based system if they got converted.
At 4.8 GB, I can guarantee it won't be nearly that fast for me.
Greetings,
For the machine I have which can run it (2011 27" iMac) it's actually kinda funny; I have an internal spinning-platters drive, but an SSD backup (via Time Machine) plugged into it. I wonder how that'd work out...if it'd try to ugprade the external drive. I mean, I'm okay with the idea of upgrading the FS; the current file system is pretty archaic at this point, but I have to admit having it muck about with my backup drive's storage makes me fidgity.
-- Morgan
I also have an external SSD on my setup, it only converted my main drive to the APFS format, the external drive remained as HFS+
also note cuda has not been upadated yet, so no cuda in 10.13 for now.
Yeah, about that.
Daz Studio 4.9 not working for me since the update. Application quits during launch.
Process: DAZStudio [12083]
Path: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
Identifier: com.DAZ.DAZStudio
Version: 4.9.4.117 (4.9.4.117)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: DAZStudio [12083]
User ID: 501
Date/Time: 2017-10-01 21:31:57.664 +0100
OS Version: Mac OS X 10.13 (17A365)
Report Version: 12
Anonymous UUID: 70E25FEF-2858-D07D-FF5F-300FB064073C
Sleep/Wake UUID: 741CCD8F-2EE1-48A9-9D1C-DB677C02794F
Time Awake Since Boot: 39000 seconds
Time Since Wake: 3100 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000060bfffffffe0
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Complete strangeness going on for me with High Sierra. All started when I ran DAZ Install Manager and noticed there were some product updates. Only a few downloaded while others gave me 'Download Failed'. Tried numerous times; same errors. Log didn't reveal anything. For the items that did download, some refused to install.
Thinking that my installs were somehow corrupted, I uninstalled everything and deleted all downloaded files. Relauched DAZ Install Manager and had the correct 113 items to re-download. This time, everything downloaded a-ok. But, only 17 items installed and 96 failed installation. e.g. Aiko 7. The log reveals: Could not extract file : /Users/Shared/My DAZ 3D Library/data/DAZ 3D/Genesis 3/Female/Morphs/DAZ 3D/Aiko 7/CTRLAiko7.dsf
But that is very odd as that file is there.
My Mac uses hard drives and so the file system was not changed at all (still on Mac OS Extended (Journaled)). What gives?
EDIT: OK, got things working. I did the same as above (uinstall, delete the install files). But additionally deleted my entire 'My DAZ 3D Library' folder. Also deleted the 'DAZ 3D' folder for good measure.
Re-dowload of the 113 items a-ok and all now installed. Only possible cause is that it was unhappy with the file/folder owner of 'My DAZ 3D Library'? I had noticed the owner was 'System' with read/write. Group was 'wheel' with read/write. and 'everyone' also had read/write. Now, the latter two are the same, but the main owner is my account I'm logged in as (with read/write). Still cannot explain why some items installed though while most didn't. Anyhow, if anyone else has issues like this, the above is hopefully a solution for you as it was for me.
With High Sierra, Daz Studio crashes during launch.
Uninstalled all and reinstalled, always crash:
Process: DAZStudio [1413]
Version: 4.10.0.101 (4.10.0.101)
Responsible: DAZStudio [1413]
User ID: 501
Date/Time: 2017-10-18 11:57:49.027 +0200
OS Version: Mac OS X 10.13 (17A405)
Report Version: 12
Anonymous UUID: FE22C310-7F00-321D-B92B-1AEDC8A77900
Time Awake Since Boot: 1700 seconds
Exception Codes: KERN_INVALID_ADDRESS at 0x000060bffffffff0
VM Regions Near 0x60bffffffff0:
MALLOC_NANO 0000608000000000-0000608000a00000 [ 10.0M] rw-/rwx SM=PRV
MALLOC_NANO 000060c000000000-000060c001200000 [ 18.0M] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x00007fff7913c608 _platform_memmove$VARIANT$Nehalem + 520
1 com.apple.CoreFoundation 0x00007fff5183af49 __CFStringCreateImmutableFunnel3 + 3177
2 com.apple.CoreFoundation 0x00007fff5184f81a CFStringCreateWithSubstring + 410
3 CUDA 0x0000000123b8414a create_version_array_from_string + 250
4 CUDA 0x0000000123b7d608 cuda_driver_initializer + 2488
5 dyld 0x000000010548da0a ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 420
6 dyld 0x000000010548dc3a ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
7 dyld 0x0000000105489170 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 330
8 dyld 0x0000000105489103 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 221
9 dyld 0x00000001054882a6 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 134
10 dyld 0x000000010548833a ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 74
11 dyld 0x000000010547c3e5 dyld::runInitializers(ImageLoader*) + 82
12 dyld 0x0000000105485002 dlopen + 527
13 libdyld.dylib 0x00007fff78ebdeb6 dlopen + 86
14 libcudart.8.0.dylib 0x0000000123b3e685 0x123b31000 + 54917
15 libcudart.8.0.dylib 0x0000000123b3e628 0x123b31000 + 54824
16 libsystem_pthread.dylib 0x00007fff791469be __pthread_once_handler + 66
17 libsystem_platform.dylib 0x00007fff7913bf00 _os_once + 33
18 libsystem_pthread.dylib 0x00007fff79146959 pthread_once + 56
19 libcudart.8.0.dylib 0x0000000123b65559 0x123b31000 + 214361
20 libcudart.8.0.dylib 0x0000000123b3e7c8 0x123b31000 + 55240
21 libcudart.8.0.dylib 0x0000000123b5ded6 cudaDriverGetVersion + 54
22 libneuray.so 0x0000000122ce36d9 0x1214bd000 + 25323225
23 libneuray.so 0x0000000122ce32dd 0x1214bd000 + 25322205
24 libneuray.so 0x0000000122ce69e1 0x1214bd000 + 25336289
25 libneuray.so 0x0000000122e43eff 0x1214bd000 + 26767103
26 libneuray.so 0x0000000122e43e33 0x1214bd000 + 26766899
27 libneuray.so 0x00000001215ec819 0x1214bd000 + 1243161
28 libneuray.so 0x00000001215ec6e7 0x1214bd000 + 1242855
29 libdzirayrenderer.dylib 0x000000011d6a09cd configuration(mi::base::Handle<mi::neuraylib::INeuray>, QString const&, QStringList const&, mi::base::Handle<mi::base::ILogger>&, DzNeurayMgr*) + 1086
30 libdzirayrenderer.dylib 0x000000011d6a12dd DzNeurayMgr::Data::Data(DzNeurayMgr*) + 669
31 libdzirayrenderer.dylib 0x000000011d6a95df DzNeurayMgr::DzNeurayMgr() + 69
32 libdzirayrenderer.dylib 0x000000011d62df9b DzNVIDIAIrayPlugin::startMgr() + 47
33 libdzirayrenderer.dylib 0x000000011d67f994 DzIrayMDLHelper::DzIrayMDLHelper() + 86
34 libdzirayrenderer.dylib 0x000000011d62866d DzTClassFactory<DzIrayMDLHelper>::createInstance() const + 37
35 libdzcore.dylib 0x0000000100de97e7 DzSettings::Data::~Data() + 65151
36 libdzcore.dylib 0x00000001002eb5ad DzAnonymousLog::Data::Data() + 34513
37 libdzcore.dylib 0x00000001002fbed9 DzAnonymousLog::Data::Data() + 102397
38 libdzcore.dylib 0x00000001002fe8ad DzAnonymousLog::Data::Data() + 113105
39 libdzcore.dylib 0x0000000100302240 DzAnonymousLog::Data::Data() + 127844
40 com.DAZ.DAZStudio 0x00000001000010b7 main + 603
41 com.DAZ.DAZStudio 0x0000000100000d58 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff7900c6da __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff7914626f _pthread_wqthread + 1552
2 libsystem_pthread.dylib 0x00007fff79145c4d start_wqthread + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:: QThread
0 libsystem_kernel.dylib 0x00007fff7900be7e __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff79147662 _pthread_cond_wait + 732
2 QtCore 0x0000000102e673dc QWaitConditionPrivate::wait(unsigned long) + 220
3 QtCore 0x0000000102e670e5 QWaitCondition::wait(QMutex*, unsigned long) + 117
4 QtWebKit 0x0000000105f17ed0 WebCore::IconDatabase::syncThreadMainLoop() + 368
5 QtWebKit 0x0000000105f197e2 WebCore::IconDatabase::iconDatabaseSyncThread() + 400
6 QtWebKit 0x0000000105f19881 WebCore::IconDatabase::iconDatabaseSyncThreadStart(void*) + 9
7 QtWebKit 0x0000000106077cb9 WTF::ThreadPrivate::run() + 19
8 QtCore 0x0000000102e665ca QThreadPrivate::start(void*) + 464
9 libsystem_pthread.dylib 0x00007fff791466c1 _pthread_body + 340
10 libsystem_pthread.dylib 0x00007fff7914656d _pthread_start + 377
11 libsystem_pthread.dylib 0x00007fff79145c5d thread_start + 13
Thread 6:
Thread 7:
1 libsystem_pthread.dylib 0x00007fff7914606a _pthread_wqthread + 1035
Thread 8:
Thread 9:
Thread 10:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff79002e76 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff79002390 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff518b7c45 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff518b6f97 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff518b6607 CFRunLoopRunSpecific + 487
5 com.apple.AppKit 0x00007fff4f0061f1 _NSEventThread + 184
6 libsystem_pthread.dylib 0x00007fff791466c1 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff7914656d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff79145c5d thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000060c000425631 rbx: 0x000060c001058221 rcx: 0x0000000000000010 rdx: 0xffffffffffbda96f
rdi: 0x000060c000000020 rsi: 0x000060c000c32bd0 rbp: 0x00007ffeefbfa400 rsp: 0x00007ffeefbfa400
r8: 0x0000000000000020 r9: 0x00000000ffffff01 r10: 0x0000000000000000 r11: 0x000060c000425630
r12: 0xffffffffffffffff r13: 0xffffffffffffff01 r14: 0x000060c000425631 r15: 0x000060c000425620
rip: 0x00007fff7913c608 rfl: 0x0000000000010286 cr2: 0x000060bffffffff0
Logical CPU: 6
Error Code: 0x00000006
Trap Number: 14
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1140
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=634.3M resident=0K(0%) swapped_out_or_unallocated=634.3M(100%)
Writable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 2
CG backing stores 2520K 4
CG image 4K 2
CoreGraphics 8K 2
CoreImage 24K 3
CoreServices 24K 2
CoreUI image data 428K 5
CoreUI image file 180K 4
Image IO 64K 2
JS JIT generated code 128.0M 2
JS JIT generated code (reserved) 1.9G 2 reserved VM address space (unallocated)
Kernel Alloc Once 8K 2
MALLOC 183.1M 527
MALLOC guard page 64K 15
Memory Tag 242 12K 2
Memory Tag 251 28K 2
STACK GUARD 56.0M 12
Stack 13.1M 12
VM_ALLOCATE 5372K 499
WebKit Malloc 2368K 3
__DATA 55.2M 428
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 252.3M 110
__TEXT 381.9M 393
__UNICODE 556K 2
mapped file 147.7M 52
shared memory 744K 14
TOTAL 3.1G 2081
TOTAL, minus reserved VM space 1.2G 2081
Model: MacBookPro10,1, BootROM MBP101.00F2.B00, 4 processors, Intel Core i7, 2,3 GHz, 16 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.190.13.1a3)
Bluetooth: Version 6.0.0f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: TS480GJDM725, 480,1 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: M3 Portable
USB Device: My Passport 0748
USB Device: USB2.0 Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Elements 10B8
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
Same problem here... Any update from DAZ?
Process: DAZStudio [2265]
Version: 4.10.0.107 (4.10.0.107)
Responsible: DAZStudio [2265]
User ID: 501
Date/Time: 2017-11-24 21:20:06.938 -0800
OS Version: Mac OS X 10.13.1 (17B48)
Report Version: 12
Anonymous UUID: 8BB2013D-929C-6ECA-8C3F-137980571918
Time Awake Since Boot: 10000 seconds
Exception Codes: KERN_INVALID_ADDRESS at 0x0000603fffffffe0
I had this crash problem. I updated my CUDA driver (in system preferences) and all is now fine. This would be an issue for anyone else with a late 2013 macbook pro that has the Nvidia card and for which you have previously installed nvidia CUDA.
Wasn't this the primary reason for Apple going to a closed system to begin with? They didn't want so many variations out there like Windows-based PCs had? I mean, you can't change the battery in their phones, I'm amazed it's not a Federal Offense/EULA violation to swap out an internal hard drive. Then again, if they're replacing the file system with one that doesn't work on platter-based drives, it's kinda the same thing innit?
Or maybe they expect you to have the latest version only, and not hang onto hardware that hasn't yet paid for itself.
I have a new 15 inch Macbook Pro running High Sierra (10.13.6). It has a dual core Intel processor and a Radeon Pro 555X 4096 MB Intel UHD Graphics card.
Will I be able to instal and run the latest version of Dax 3D?
Rob says
I personally test on machines primarily running Mac OS X 10.6.8, macOS 10.13.6, and macOS 10.14... with the potential to mount/boot the latest build of the various versions in between.
