High Sierra for Mac avilable at App Store now and Daz Studio loves it!
High Sierra is out and at the App Store just for you. Download and install aprox. 1 hour in total. Get it now and have fun! It is great to be out of the beta now. I have a couple of hundred apps and the only one that broke (and I was told by developer in advance that it would)was Drive Genius. Zero problems with anything else! Daz Studio works even faster on my Mac than it did before the new OS!
    Greetings,
    *sigh*
    My laptop Mac is now TWO operating system versions behind. :-/
    I love my 17" MacBook Pro, and I _really_ didn't want to get a 15", but...this isn't going to be sustainable.
    Thanks for the info, though!
    --  Morgan
  • gsm77gsm77 Posts: 23
    I am looking forward to eventually trying it. At the moment it is not possiable because it is not supported on Hybrid drives that my imac has. I hope they can remedy this soon.
    Greetings,
    @gsm77 You most certainly can run Mac OS X High Sierra on a hybrid drive or plain hard drive, it just doesn't upgrade your file system to the new APFS.  While APFS is a pretty big feature, it's not the only one in the new version, so it's probably worth updating if you can.
    --  Morgan
  • EsemwyEsemwy Posts: 578
    Looks like I need to wait for a new driver from Nvidia before I can have a go. sad
    Thanks i may now consider upgrading in the next week or so.
  • Seven193Seven193 Posts: 1,156
    No thanks, this upgrade replaces your entire file system, so I'm not in any hurry to experiment without backing up data.
  • inquireinquire Posts: 2,458
    Might want to check the Apple Discussions, under Support, and High Sierra, at Apple.com. Seems pretty safe, but I did check with Alsoft, which makes DiskWarrior, which can really repair problems at which Apple's Disk Utility may fail. Alsoft says they have to prepare a whole new version because of the APS file system. But, supposedly, if you have, as do I, an SSD drive in your main Mac, that will be automatically converted to the new file system. Then, for backup drives, I have the standard spinning drives from La Cie. I was told that's not a problem, and that High Sierra can both read from and write to regular hard drives. (Just saying some of what's over at Apple's Discussions. I'm not insisting this is the absolute truth.)
    Anyone who is going to upgrade, though, should have a full, complete backup on another HD. Also, a caveat I've sadly learned is true: The leading edge, the cutting edge, is often the bleeding edge. In other words, it may be safer for a bit to read about the new features in High Sierra, and wait until we get the 10.13.2 or 10.13.3 versions out, which will probably remove some of the bugs. For regular Sierra, I'm at 10.12.6. There are always some bugs that are later discovered. They can't possibly test out all the various versions of Macs and Mac OSs that exist.
    edited September 2017
    Yeah, if I had external backup drives, I wouldn't want Sierra trying to convert those, or any other non-OS drives connected to the system.  I don't think you would be able to read them from Windows OS-based system if they got converted.
    Post edited by Seven193 on
  • Download and install aprox. 1 hour in total.
    At 4.8 GB, I can guarantee it won't be nearly that fast for me.
    Greetings,
    For the machine I have which can run it (2011 27" iMac) it's actually kinda funny; I have an internal spinning-platters drive, but an SSD backup (via Time Machine) plugged into it.  I wonder how that'd work out...if it'd try to ugprade the external drive.  I mean, I'm okay with the idea of upgrading the FS; the current file system is pretty archaic at this point, but I have to admit having it muck about with my backup drive's storage makes me fidgity.
    --  Morgan
  • CypherFOX said:
    Greetings,
    --  Morgan
    I also have an external SSD on my setup, it only converted my main drive to the APFS format, the external drive remained as HFS+
    also note cuda has not been upadated yet, so no cuda in 10.13 for now.
  • High Sierra is out and at the App Store just for you. Download and install aprox. 1 hour in total. Get it now and have fun! It is great to be out of the beta now. I have a couple of hundred apps and the only one that broke (and I was told by developer in advance that it would)was Drive Genius. Zero problems with anything else! Daz Studio works even faster on my Mac than it did before the new OS!
    Yeah, about that.
    Daz Studio 4.9 not working for me since the update. Application quits during launch.
    Process:               DAZStudio [12083]
    Path:                  /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
    Identifier:            com.DAZ.DAZStudio
    Version:               4.9.4.117 (4.9.4.117)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           DAZStudio [12083]
    User ID:               501
    Date/Time:             2017-10-01 21:31:57.664 +0100
    OS Version:            Mac OS X 10.13 (17A365)
    Report Version:        12
    Anonymous UUID:        70E25FEF-2858-D07D-FF5F-300FB064073C
    Sleep/Wake UUID:       741CCD8F-2EE1-48A9-9D1C-DB677C02794F
    Time Awake Since Boot: 39000 seconds
    Time Since Wake:       3100 seconds
    System Integrity Protection: enabled
    Crashed Thread:        0  Dispatch queue: com.apple.main-thread
    Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes:       KERN_INVALID_ADDRESS at 0x000060bfffffffe0
    Exception Note:        EXC_CORPSE_NOTIFY
    Termination Signal:    Segmentation fault: 11
    Termination Reason:    Namespace SIGNAL, Code 0xb
    Terminating Process:   exc handler [0]
  • rsharprsharp Posts: 45
    edited October 2017
    Complete strangeness going on for me with High Sierra.  All started when I ran DAZ Install Manager and noticed there were some product updates.  Only a few downloaded while others gave me 'Download Failed'.  Tried numerous times; same errors.  Log didn't reveal anything.   For the items that did download, some refused to install.
    Thinking that my installs were somehow corrupted, I uninstalled everything and deleted all downloaded files.  Relauched DAZ Install Manager and had the correct 113 items to re-download.  This time, everything downloaded a-ok.  But, only 17 items installed and 96 failed installation.  e.g. Aiko 7.  The log reveals: Could not extract file : /Users/Shared/My DAZ 3D Library/data/DAZ 3D/Genesis 3/Female/Morphs/DAZ 3D/Aiko 7/CTRLAiko7.dsf
    But that is very odd as that file is there.
    My Mac uses hard drives and so the file system was not changed at all (still on Mac OS Extended (Journaled)).  What gives?
    EDIT: OK, got things working.  I did the same as above (uinstall, delete the install files).  But additionally deleted my entire 'My DAZ 3D Library' folder.  Also deleted the 'DAZ 3D' folder for good measure.
    Re-dowload of the 113 items a-ok and all now installed.   Only possible cause is that it was unhappy with the file/folder owner of 'My DAZ 3D Library'?  I had noticed the owner was 'System' with read/write.  Group was 'wheel' with read/write.  and 'everyone' also had read/write.  Now, the latter two are the same, but the main owner is my account I'm logged in as (with read/write).  Still cannot explain why some items installed though while most didn't.  Anyhow, if anyone else has issues like this, the above is hopefully a solution for you as it was for me.
    Post edited by rsharp on
  • With High Sierra, Daz Studio crashes during launch.
    Uninstalled all and reinstalled, always crash:
    Process:               DAZStudio [1413]
    Version:               4.10.0.101 (4.10.0.101)
    Responsible:           DAZStudio [1413]
    User ID:               501
    Date/Time:             2017-10-18 11:57:49.027 +0200
    OS Version:            Mac OS X 10.13 (17A405)
    Report Version:        12
    Anonymous UUID:        FE22C310-7F00-321D-B92B-1AEDC8A77900
    Time Awake Since Boot: 1700 seconds
    Exception Codes:       KERN_INVALID_ADDRESS at 0x000060bffffffff0
    VM Regions Near 0x60bffffffff0:
        MALLOC_NANO            0000608000000000-0000608000a00000 [ 10.0M] rw-/rwx SM=PRV
        MALLOC_NANO            000060c000000000-000060c001200000 [ 18.0M] rw-/rwx SM=PRV
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   libsystem_platform.dylib          0x00007fff7913c608 _platform_memmove$VARIANT$Nehalem + 520
    1   com.apple.CoreFoundation          0x00007fff5183af49 __CFStringCreateImmutableFunnel3 + 3177
    2   com.apple.CoreFoundation          0x00007fff5184f81a CFStringCreateWithSubstring + 410
    3   CUDA                              0x0000000123b8414a create_version_array_from_string + 250
    4   CUDA                              0x0000000123b7d608 cuda_driver_initializer + 2488
    5   dyld                              0x000000010548da0a ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 420
    6   dyld                              0x000000010548dc3a ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
    7   dyld                              0x0000000105489170 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 330
    8   dyld                              0x0000000105489103 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 221
    9   dyld                              0x00000001054882a6 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 134
    10  dyld                              0x000000010548833a ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 74
    11  dyld                              0x000000010547c3e5 dyld::runInitializers(ImageLoader*) + 82
    12  dyld                              0x0000000105485002 dlopen + 527
    13  libdyld.dylib                     0x00007fff78ebdeb6 dlopen + 86
    14  libcudart.8.0.dylib               0x0000000123b3e685 0x123b31000 + 54917
    15  libcudart.8.0.dylib               0x0000000123b3e628 0x123b31000 + 54824
    16  libsystem_pthread.dylib           0x00007fff791469be __pthread_once_handler + 66
    17  libsystem_platform.dylib          0x00007fff7913bf00 _os_once + 33
    18  libsystem_pthread.dylib           0x00007fff79146959 pthread_once + 56
    19  libcudart.8.0.dylib               0x0000000123b65559 0x123b31000 + 214361
    20  libcudart.8.0.dylib               0x0000000123b3e7c8 0x123b31000 + 55240
    21  libcudart.8.0.dylib               0x0000000123b5ded6 cudaDriverGetVersion + 54
    22  libneuray.so                      0x0000000122ce36d9 0x1214bd000 + 25323225
    23  libneuray.so                      0x0000000122ce32dd 0x1214bd000 + 25322205
    24  libneuray.so                      0x0000000122ce69e1 0x1214bd000 + 25336289
    25  libneuray.so                      0x0000000122e43eff 0x1214bd000 + 26767103
    26  libneuray.so                      0x0000000122e43e33 0x1214bd000 + 26766899
    27  libneuray.so                      0x00000001215ec819 0x1214bd000 + 1243161
    28  libneuray.so                      0x00000001215ec6e7 0x1214bd000 + 1242855
    29  libdzirayrenderer.dylib           0x000000011d6a09cd configuration(mi::base::Handle<mi::neuraylib::INeuray>, QString const&, QStringList const&, mi::base::Handle<mi::base::ILogger>&, DzNeurayMgr*) + 1086
    30  libdzirayrenderer.dylib           0x000000011d6a12dd DzNeurayMgr::Data::Data(DzNeurayMgr*) + 669
    31  libdzirayrenderer.dylib           0x000000011d6a95df DzNeurayMgr::DzNeurayMgr() + 69
    32  libdzirayrenderer.dylib           0x000000011d62df9b DzNVIDIAIrayPlugin::startMgr() + 47
    33  libdzirayrenderer.dylib           0x000000011d67f994 DzIrayMDLHelper::DzIrayMDLHelper() + 86
    34  libdzirayrenderer.dylib           0x000000011d62866d DzTClassFactory<DzIrayMDLHelper>::createInstance() const + 37
    35  libdzcore.dylib                   0x0000000100de97e7 DzSettings::Data::~Data() + 65151
    36  libdzcore.dylib                   0x00000001002eb5ad DzAnonymousLog::Data::Data() + 34513
    37  libdzcore.dylib                   0x00000001002fbed9 DzAnonymousLog::Data::Data() + 102397
    38  libdzcore.dylib                   0x00000001002fe8ad DzAnonymousLog::Data::Data() + 113105
    39  libdzcore.dylib                   0x0000000100302240 DzAnonymousLog::Data::Data() + 127844
    40  com.DAZ.DAZStudio                 0x00000001000010b7 main + 603
    41  com.DAZ.DAZStudio                 0x0000000100000d58 start + 52
    Thread 1:
    0   libsystem_kernel.dylib            0x00007fff7900c6da __workq_kernreturn + 10
    1   libsystem_pthread.dylib           0x00007fff7914626f _pthread_wqthread + 1552
    2   libsystem_pthread.dylib           0x00007fff79145c4d start_wqthread + 13
    Thread 2:
    Thread 3:
    Thread 4:
    Thread 5:: QThread
    0   libsystem_kernel.dylib            0x00007fff7900be7e __psynch_cvwait + 10
    1   libsystem_pthread.dylib           0x00007fff79147662 _pthread_cond_wait + 732
    2   QtCore                            0x0000000102e673dc QWaitConditionPrivate::wait(unsigned long) + 220
    3   QtCore                            0x0000000102e670e5 QWaitCondition::wait(QMutex*, unsigned long) + 117
    4   QtWebKit                          0x0000000105f17ed0 WebCore::IconDatabase::syncThreadMainLoop() + 368
    5   QtWebKit                          0x0000000105f197e2 WebCore::IconDatabase::iconDatabaseSyncThread() + 400
    6   QtWebKit                          0x0000000105f19881 WebCore::IconDatabase::iconDatabaseSyncThreadStart(void*) + 9
    7   QtWebKit                          0x0000000106077cb9 WTF::ThreadPrivate::run() + 19
    8   QtCore                            0x0000000102e665ca QThreadPrivate::start(void*) + 464
    9   libsystem_pthread.dylib           0x00007fff791466c1 _pthread_body + 340
    10  libsystem_pthread.dylib           0x00007fff7914656d _pthread_start + 377
    11  libsystem_pthread.dylib           0x00007fff79145c5d thread_start + 13
    Thread 6:
    Thread 7:
    1   libsystem_pthread.dylib           0x00007fff7914606a _pthread_wqthread + 1035
    Thread 8:
    Thread 9:
    Thread 10:: com.apple.NSEventThread
    0   libsystem_kernel.dylib            0x00007fff79002e76 mach_msg_trap + 10
    1   libsystem_kernel.dylib            0x00007fff79002390 mach_msg + 60
    2   com.apple.CoreFoundation          0x00007fff518b7c45 __CFRunLoopServiceMachPort + 341
    3   com.apple.CoreFoundation          0x00007fff518b6f97 __CFRunLoopRun + 1783
    4   com.apple.CoreFoundation          0x00007fff518b6607 CFRunLoopRunSpecific + 487
    5   com.apple.AppKit                  0x00007fff4f0061f1 _NSEventThread + 184
    6   libsystem_pthread.dylib           0x00007fff791466c1 _pthread_body + 340
    7   libsystem_pthread.dylib           0x00007fff7914656d _pthread_start + 377
    8   libsystem_pthread.dylib           0x00007fff79145c5d thread_start + 13
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x000060c000425631  rbx: 0x000060c001058221  rcx: 0x0000000000000010  rdx: 0xffffffffffbda96f
      rdi: 0x000060c000000020  rsi: 0x000060c000c32bd0  rbp: 0x00007ffeefbfa400  rsp: 0x00007ffeefbfa400
       r8: 0x0000000000000020   r9: 0x00000000ffffff01  r10: 0x0000000000000000  r11: 0x000060c000425630
      r12: 0xffffffffffffffff  r13: 0xffffffffffffff01  r14: 0x000060c000425631  r15: 0x000060c000425620
      rip: 0x00007fff7913c608  rfl: 0x0000000000010286  cr2: 0x000060bffffffff0
    Logical CPU:     6
    Error Code:      0x00000006
    Trap Number:     14
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 1
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 1140
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=634.3M resident=0K(0%) swapped_out_or_unallocated=634.3M(100%)
    Writable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)
                                      VIRTUAL   REGION
    REGION TYPE                          SIZE    COUNT (non-coalesced)
    Accelerate framework                 384K        3
    Activity Tracing                     256K        2
    CG backing stores                   2520K        4
    CG image                               4K        2
    CoreGraphics                           8K        2
    CoreImage                             24K        3
    CoreServices                          24K        2
    CoreUI image data                    428K        5
    CoreUI image file                    180K        4
    Image IO                              64K        2
    JS JIT generated code              128.0M        2
    JS JIT generated code (reserved)     1.9G        2         reserved VM address space (unallocated)
    Kernel Alloc Once                      8K        2
    MALLOC                             183.1M      527
    MALLOC guard page                     64K       15
    Memory Tag 242                        12K        2
    Memory Tag 251                        28K        2
    STACK GUARD                         56.0M       12
    Stack                               13.1M       12
    VM_ALLOCATE                         5372K      499
    WebKit Malloc                       2368K        3
    __DATA                              55.2M      428
    __FONT_DATA                            4K        2
    __GLSLBUILTINS                      2588K        2
    __LINKEDIT                         252.3M      110
    __TEXT                             381.9M      393
    __UNICODE                            556K        2
    mapped file                        147.7M       52
    shared memory                        744K       14
    TOTAL                                3.1G     2081
    TOTAL, minus reserved VM space       1.2G     2081
    Model: MacBookPro10,1, BootROM MBP101.00F2.B00, 4 processors, Intel Core i7, 2,3 GHz, 16 GB, SMC 2.3f36
    Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
    Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1 GB
    Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
    Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.190.13.1a3)
    Bluetooth: Version 6.0.0f7, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en0
    Serial ATA Device: TS480GJDM725, 480,1 GB
    USB Device: USB 2.0 Bus
    USB Device: Hub
    USB Device: FaceTime HD Camera (Built-in)
    USB Device: Hub
    USB Device: Hub
    USB Device: Apple Internal Keyboard / Trackpad
    USB Device: BRCM20702 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: USB 3.0 Bus
    USB Device: USB3.0 Hub
    USB Device: M3 Portable
    USB Device: My Passport 0748
    USB Device: USB2.0 Hub
    USB Device: Keyboard Hub
    USB Device: Apple Keyboard
    USB Device: Elements 10B8
    Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
  • Same problem here... Any update from DAZ?
    Process:               DAZStudio [2265]
    Version:               4.10.0.107 (4.10.0.107)
    Responsible:           DAZStudio [2265]
    User ID:               501
    Date/Time:             2017-11-24 21:20:06.938 -0800
    OS Version:            Mac OS X 10.13.1 (17B48)
    Report Version:        12
    Anonymous UUID:        8BB2013D-929C-6ECA-8C3F-137980571918
    Time Awake Since Boot: 10000 seconds
    Exception Codes:       KERN_INVALID_ADDRESS at 0x0000603fffffffe0
  • SirFurboySirFurboy Posts: 11
    edited December 2017
    I had this crash problem. I updated my CUDA driver (in system preferences) and all is now fine. This would be an issue for anyone else with a late 2013 macbook pro that has the Nvidia card and for which you have previously installed nvidia CUDA.
    Post edited by SirFurboy on
    Wasn't this the primary reason for Apple going to a closed system to begin with? They didn't want so many variations out there like Windows-based PCs had? I mean, you can't change the battery in their phones, I'm amazed it's not a Federal Offense/EULA violation to swap out an internal hard drive. Then again, if they're replacing the file system with one that doesn't work on platter-based drives, it's kinda the same thing innit?
    Or maybe they expect you to have the latest version only, and not hang onto hardware that hasn't yet paid for itself.
  • ValKyrieValKyrie Posts: 137
    I have a new 15 inch Macbook Pro running High Sierra (10.13.6). It has a dual core Intel processor and a Radeon Pro 555X 4096 MB Intel UHD Graphics card.
    Will I be able to instal and run the latest version of Dax 3D?
    Rob says
    I personally test on machines primarily running Mac OS X 10.6.8, macOS 10.13.6, and macOS 10.14... with the potential to mount/boot the latest build of the various versions in between.
