Adam's apple needed for G8 Male
ThatGuy
Please we could use additional face and body morphs for G8 Male. Enough has already been rolled out for the female version. I really need an adam's apple for my G8 male characters.
Hope this helps, it's a very simple morph I've made. Just unzip it, open it up and put the My Library folder into your Studio folder. You can find the morph in the Parameters tab of Genesis 8 Male => Actor => Head => Neck
Thank you Estroyer! Looking forward to trying this morph out.
Thank you Estroyer very handy
Is there any way to use this on G8 Female? I have a couple of pieces that could really use it.
As FWIW said is there any way to convert this
There is! With the Transfer Utility (TU)
1. Load G8F and G8M into the scene
2. Add Adam's Apple morph to favorites
3. Open TU (Assets -> Transfer Utility)
4. Set G8M as source and G8F as target
5. Set G8M type to "Current" and G8F type to "Clone: Genesis 8 Male"
6. Click ">> Show Options"
7. Uncheck "Weight Maps," "Selection Map," "Face Groups," "Region Groups," "Fit to Source Figure" and "Parent to Source Figure"
8. Under "Morph Targets" set the "From Source" dropdown to "Favorites"
The transfered morph will be under Head/Neck on G8F!
