Refresh Artworks by Waleed Karajah 2
THIS IS WHAT i'M GOING TO PROVE TO MY FRIENDS ON BRYCE 5.0 ABOUT LIGHTING AND HOW WE CREATE A PART OF A CITY IN THE NIGHT done by Bryce 5.0 THIS IS ONE OF MY TRIES i HOPE FINALLY I REACH TO MY WISHES IN THIS CASE SOMETIMES i FACE PROBLEMS WITH THE BRYCE ENGINES WHICH STOPPED IN THE MIDDLE OF RENDERING THE ARTWORK WHICH BEEN DAMAGED MY STUDENTS IN THE UNIVERSITY TOLD ME TO CHANGE THE THE vga card AND TRY FOR NVIDIA GFORCE THEY SAID IT IS GOOD FOR SMALL SOFTWARE LIKE BRYCE AND OTHER SOFTWARE I TRY TO TEST A ONE IT IS REALLY GOOD FOR REN DERING WITH THIS ENGINE
I'M WORKING ON BRYCE SINCE LONG TIME I LEARNED HOW TO FIX PROBLEMS I KNEW FROM WHERE???? WHEN I PUT THE PALMS TREES I FACE PROBLEM TO LOOS MY WORK .........
IT HAPPENED I DON'T KNOW IS THERE A PROBLEM WITH TREES IN BRYCE WHY EVERYTHING GONNA BE ALRIGHT UNTIL I PUT THE PALMS TREES WHY I TRY TO SAVE STEP BY STEP TO NOT LOOS MY WORK AND I TRY TO SAVE MANY FILES EVERY TIME
I HOPE IT IS BEEN SOLVED IN BRYCE 7.0 PRO
ALSO I THINK TOO MUCH THINGS IT WILL MAKE THE SAME THING ......
i HOPE FROM THE EXPERTS WHO MADE THIS NICE SOFTWARE TRY TO IMPROVE THIS ISSUE BY LISTENING TO USERS HOW ABOUT THE PROBLEM THEY FACED ....... CAREFULLY AND GIVE RIGHT SOLUTIONS NOT TO GUESS IT ....... I HOPE
Gray color 2 and new Bridge Lighting 2 here the bridge colored image
Waleed: As far as I know, the graphics card in your computer has little to no relevance to Bryce as the application uses the main processor and not the video card.
NO , sorry you should change your believes about this case the graphic card can render the image in excellent time render without any problems this happened to me my friend ............... yes as I told you
here is continuing the Tower magic shadowing .............
Beautiful city night lights renders Waleed, first picture is amazing. Your renders are getting better and better .
Here is my fav video song and you can see night lights too
Gareth Emery feat. Christina Novelli - Concrete Angel [Official Music Video]
One question : If the buildings are Archmodels how do i import or use a .max file into Bryce ? I have a nice free chinese building from http://www.3dmodelfree.com/3dmodel/list476-1.htm but it's in .max format and i don't want to install trial/or free edition 3 DS Max for a building ..
I don't know if the free (Standalone) Autodesk FBX Converter http://mexico.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775855 helps but i might give it a try when i will learn how to use it lol.
And i don't know if max files are scenes or objects with additional settings or just a simple object like .obj
Edit: Oh so .max files are scenes not only the object according to http://www.fileinfo.com/extension/max ..to bad
Many thanks ,
if you use max why u should use Bryce sorry for this Bryce have something little because Bryce small software with the comparative of Max
Max has many abilities which give realistic images but Bryce you should use some software with to accept your finish of your images
New in Miami night towers
work from inside Bryce 5.0
Miami Towers Daylight vision
Old Artwork for me
going back to the CITY TOWERS FUTURISTIC STYLE with two scenes night vision one in the eve. other in the midnight
ONCE AGAIN THE CITY TOWERS 4
Continuing the City towers 4
Nice renders, but they'd be possible in any bryce version other than 7 and in 7 as well, if you're not depending on volume lighting.
Two different kinds of lighting
Sci-Fi / Space old artwork for me done by Bryce 5.0 hope you like this ..........
cool renders
Thanks , this was old artworks , but I love looking at it always
Sci-Fi / Space again
New test for Architectural concept on Bryce lighting we still working wait us for the fantastic results
Again wjth the villa and other artwoks
don't know what to add but great job on all
Thanx , yes I have too much artworks so I don't know what to add ..... and the important thing is the experimental test of the lighting effects
this is the real project I'm interest in
The villa again in night
still we have a problems with the trees in balancing light , see this two images above this thread
this scene is new editing and adding
another editing for this hotel hope you like
the villa again with new light test
this is new job of lighting test but it was crash I took this unrendered shot but it is fine I was cooking my new work on a quite fire
after finish the original file I will download it soon
tests of lighting
So here I can see your work :)
Greetz.... Lisa-Lisette
