Duplicate IDs were found...
Hello All,
Sometimes I get this message when I open a saved scene in DAZ Studio but after I click on OK my scene completely loads with no further issue. Could someone tell me what may cause this message?  (see attached screenshot)
Thank you!
  • That's generally older (pre-DS 4.5) content. I do have a script to fix the basic content, though by now most things shold be updated at source. https://www.daz3d.com/forums/discussion/740/daz-studio-4-5-fix-duplicate-ids-script/p1
    Thank you very much, Richard! I was wondering about this and since it did not cause any problems with the scene itself I just overlooked it. Thanks again!
  • DannisWritesDannisWrites Posts: 53
    edited January 2020
    I have this error and I've tried to run the Duplicate IDs Script, but I still have it. Here's the log file [attached].
    My render turned out normally.
    Well, my files are refusing to upload right now. Here's part of the log file:
    2020-01-07 22:03:30.223 *** Scene Cleared ***
    2020-01-07 22:03:57.474 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1353): Failed to create uv set!
    2020-01-07 22:03:58.601 Duplicate id "SY Long Tunic Template G3M" found in file "/data/DAZ 3D/Genesis 8/Male/Tools/Projection Templates/Ultra Templates/SYUT Long Tunic Template Genesis 8 Male/SY Long Tunic Template G8M_58487.dsf"
    2020-01-07 22:03:58.601 Duplicate id "SY Long Tunic Template G3M_58487" found in file "/data/DAZ 3D/Genesis 8/Male/Tools/Projection Templates/Ultra Templates/SYUT Long Tunic Template Genesis 8 Male/SY Long Tunic Template G8M_58487.dsf"
    2020-01-07 22:03:58.601 Duplicate id "hip" found in file "/data/DAZ 3D/Genesis 8/Male/Tools/Projection Templates/Ultra Templates/SYUT Long Tunic Template Genesis 8 Male/SY Long Tunic Template G8M_58487.dsf"
    2020-01-07 22:03:58.601 Duplicate id "pelvis" found in file "/data/DAZ 3D/Genesis 8/Male/Tools/Projection Templates/Ultra Templates/SYUT Long Tunic Template Genesis 8 Male/SY Long Tunic Template G8M_58487.dsf"
    ... a long list but same file. When I tried to run the script on it, got an error message referring me to the log file, so here's that part:
    2020-01-08 21:51:40.328 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01020 iterations after 2720.227s.
    2020-01-08 21:51:40.328 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2020-01-08 21:55:57.257 Script executed successfully: D:/3D/_3D Assets/Scripts/Fix Duplicate IDs/Fix Duplicate IDs.dsa
    2020-01-08 21:56:03.730 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01122 iterations after 2983.621s.
    2020-01-08 21:56:03.730 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    ... as you can see, the log file makes no mention that I got an error on running the script. It is similar to the other poster's error.
    Post edited by DannisWrites on
  • I don't think my script would check templates. Have you tried redownloading the product from your account? I'm pretty sure it would have been updated to fix the issue, I think I have the template set installed without getting the error.
