Popobawa Tail morph missing?
SnowSultan
Anyone who's seen my art knows I had to jump on that product. ;) I do have a question though, in the description it says there is a "Tail Wider" morph, but I can't find it. If anyone can, could you let me know? Thanks in advance for any help.
I also can't find a Readme, but if you hit the wings with SubD (in Studio), they look a lot better.
I know where the Readme is:
http://docs.daz3d.com/doku.php/public/read_me/index/15909/start
The file list DOES mention a \data\DAZ 3D\Genesis\Base\Morphs\WillDupre\CatgirlGenesis\TailWider.dsf
See the CatgirlGenesis? I think this is the reason it doesn't show - the other morphs are in
\data\WillDupre\BatDemon\BatDemonFeet\BatDemonFeet.dsf
Bug report
https://bugs.daz3d.com/view.php?id=49965
Actually the tail wider is controlled from within genesis that's why you don't see the dial in the tail. the reason being is that the wider morph actually expands the connection point on genesis as well as the tail itself. In genesis it is the same morph as the one that the catgirl tail uses(as well as the wolf fox) that's why the file path says catgirl. you can find the dial in the genesis parameters under Actor/Lower Body/Hip
Just checked and can confirm that with Genesis selected in my Parameters tab, I find "tail wider" here... Actor/Lower Body/Hip/Female/Fantasy SciFi
Thanks very much! :)
:red:
well, someone had to...
Looks great Jabba. :) Should be able to make some very mean looking male devils with this set and some Freak and Creature morphs.
I immediately thought of the old gargoyles cartoon and that made me happy.
