Genesis 3/8 - line where Anatomy prop meets body, how do I get rid of it?
arcady
In the screenshot attached... how do I get rid of that line seen where the body and the anatomy prop meet?
Is there anything that can be done about this?
This image is Monique 7. I'm seeing this in Genesis 8 as well.
It's not as easy to find on some skin tones than others, but I need a dark skinned model and this line is really getting in the way of things...
Can this be controlled with lighting, adjusting shaders on the prop, or something?
If this helps, that is a 3Delight render. I am testing right now in Iray and NOT getting this issue.
I used the 3Delight mats for 3Delight and the Iray mats for Iray.
Going to try the iRay mats in 3Delight and see what happens.
Is there a tutorial anywhere for the render settings in Iray... It seems to be an amazingly slow renderer which makes me think I have the settings dialed up way to high for just 'testing things out'...
It's been suggested I could fix this with 'surface settings' on the prop, so also looking into that.
For your Monique 7 issue: Make sure that you have the same SSS setting applied to both her, and her anatomy, or it could be that the specular settings are slightly different. The area bellow the line looks to be shinier.
About Iray: You need to have a resonably fast Nvidia Geforce video card with at least 2GB of Video RAM (4GB or more is recomended) for fast rendering.
