Issue with Cart?
shg0816_13461e8196shg0816_13461e8196 Posts: 352
I tried adding Black Kitty to my cart, and the first time it appears to have taken.
However, the cart still shows "0" items in there. When I tried re-adding the item, I get the error message stating, maximum allowed purchase is 1.
Any thoughts?
I don't want to miss the 30% savings, but if I do, I guess I won't be getting said item.
    make sure that you are fully logged into the store, then put a different item into your cart. It doesn't matter what it is, because when you then view your cart you should see the original item. remove the item you don't need and proceed to checkout, or carry on shopping, whichever is your choice. :)
  • shg0816_13461e8196shg0816_13461e8196 Posts: 352
    Great, thank you!!
