Trouble with rendering in DS4.5 Pro
jaebea
Lately, I have been getting these odd, colorful artifacs in my renders. I am using uberlighting 2 and one regular light. What's even stranger is that if I render this again, the artifacs will be different. I can't seem to get a clean render anymore! Has anyone else had this problem? Click on the image and you see them more clearly.
Post edited by jaebea on
Those are caused by an Error in the 3Delight render engine. It is a known error. To fix it Change all lights to Ray Traced Shadows. Just one light set to Deep Shadow Maps can cause the errors you are getting.
I get this too, it is really annoying. Using ray-traced lights takes 10 times longer than shadow maps but does fix it. Another solution is to render it twice and over lay both images in an image editor then erase parts of the top image that have the artifacts to reveal the one below that doesn't have them.
This error has been around for about a year and still not been fixed :(
More than a year I think and yes it should be fixed but for correctness sake it is 3Delight, as far as I am aware, that is at fault and not Daz Studio. It has been suggested and seems to work in some cases that moving the camera very slightly when using Deep Shadow Mapped Shadows can help to aviod the artifatcs but since I have never seen this myself I can say for sure if it works,
Thanks! That was the problem. I can see I will have to make some lighting adjustments but that's ok!!
