Luxus discussion
Adding to Cart…
DAZ's wood shader? I can use luxrender wood mats just fine,
thanks for the diamond comment,
I realised I needed some relfections to make it look even plausable, so I used a cube mesh light (.5m a side) and the scene is inside a 12 sided cylinder (white glossy material) which gave me the reflections on the diamond ( I think, could just be the mesh light showing up there.. )
I have several wood shaders including some with Macs sets most stuff does translate with Reality just need to tweak the materials. No matter what plug in one uses i thin it's best to do so.. I know we will have much more options in R3
It is my understanding that unbiased rendering engines do eventually reach resolution, just that the point at which they do is far longer then anyone would care to let them go, especially as it becomes a case of diminishing returns. It's a subtle point, but sometimes subtle points can make a world of difference in some strange situation. As for a 'working' reference, it effectively never stops.
This has got too complicated. And I like complication.
Applying natural surfaces with Luxus is a nightmare.
What do you mean by a natural surface?
I am not proficient in the finer points of Lux material settings. If I were I'd use Luxblender.
The main reason I use Studio, is that I do not what to deal with the complications of Luxblender.
We can probably help you out. What kind of surface are you looking for?
At the least I'd like to see some generic presets that take full advantage of Lux. SSS human skin would be a good start.
+1
The automatic translation of Human/UberSurface is a SSS skin. It is a glossytranslucent with a scattering volume.
To setup a similar thing manually, take a look at the LuxusText scene. Its skin is a little on the pink side, but it shows how to get a more organic look.
The autotranslation of Human/UberSurface can be improved, but to achieve the maximum possibe realness, an artist will have to make textures specifically for LuxRender. I am guessing this is not what you want to hear. Hopefully artist will embrace LuxRender.
They should its a great rendering engine and it's free
Hmm. Bree at default looks not good. Blue SSS .
I'm not convinced.
I will certainly see about improving it.
I think it would be more technically correct to say they eventually run into the brick wall that is numerical precision. And that isn't necessarily as far out there as you might want to believe it is. Lux uses floats for speed and to reduce memory consumption. If it switched to doubles then the second half of your statement probably becomes true. But such a change would have a very serious impact on performance and memory requirements.
Any word on the basic tutorials for first timers from Bluebird 3D?
I don't understand a word being said in this thread anymore. :)
yes please, I thought Daz had them on Friday, tho it is only Tuesday, maybe it will be s**n :)
You can get renders that are done in under 1000S/p, but it depends a lot on scene construction, and they almost always are lit by a single IBL. Which brings me to the other point I forgot to mention: Not only does Lux prefer HDRs for environment lights, but you will get significantly better render performance if you load them as an infinite light rather than as an area light, such as your ring is. When you use an area light, internally Lux basically treats each face in the mesh as a separate light. The more faces in the mesh, the slower it will render. If you are going to create separate HDR resources for use in Lux, you'd be best off using one of the projection mappings that Lux supports so they can be loaded as an IBL, which counts as only a single light internally and thus renders much faster. See http://www.luxrender.net/wiki/Environment_map for details on the projections supported.
I'm sorry, we've been misunderstanding each other. The Ring of Light is not, was not designed to be, and isn't intended to be an IBL. I'm sure it's the 'environment lighting' tag that lead to the misunderstanding. Thanks for the help and the links. They have really helped me get a better understanding of lighting settings and values in Lux :-)
Yes, I know Ring of Light is not meant to be an IBL, but rather uses area light techniques. I was just making suggestions for what needs to be considered if you make future products that you want to also provide optimal support for LuxRender in.
And even without being an IBL, HDRs are still better for area lights such as Ring of Lights than LDRs are.
There are some tweaks to get SSS looking right, someone here posted setting to use with the Glossy Translucent with homogenous volume, which were a good start,
3 hours 50 minutes 2.82K S/p
oooh got me eyes peeled now Rareth. ;)
I am still playing with the one small scene.
Changed the area in to a SunSky2 but it states in the LuxWiki that to get softer shadows try adjsting the Sun Size parameter which I see in Daz Studio. Up or down for softer and how far. I tried 2.00 and -2.00 an didn't see much difference or should I be waiting longer at render to see the results. Yeah I know I should wiat until I get a better computer so I can test this myself but it is so much fun I just want to learn more now. ;)
I think I need some help. Please?
I have LuxRender installed, and up and running, my DAZ Studio is 4.5 Pro, but, when I tried to install Luxus, and tried to check Help >About Installed Plugins, it gives me a red mouse icon. When I clicked on Luxus, the information window said that the 'Plugin Failed to Load!' with the reason 'Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.' I even redownloaded the exe for the plugin.
I had had to redownload Studio 4.5 a month or two ago, and I thought I had the latest version, but the 'About DAZ Studio' window says that it's version 4.5.0.26. Is that what I've done?
I have Windows 7 on a 32 bit system.
Would it be possible to add an 'Auto Transfer' option to the 'Luxus - LuxRender Material' box? I'm slowly learning how to setup materials, but it would be a lot easier if the material settings could be auto-populated with what they get set to if you send the scene to LuxRender with DS materials.
make sure you have the 32 bit version of Luxus it comes in both 32 and 64 bit versions, I downloaded the wrong one at first too.
Studio should be 4.5.1.56
The current version of Daz Studio is 4.5.1.56, not sure if Luxus requires the latest version or not.
I've never been able to get good hybrid results from Lux, but with all the options on the table with Luxus I'm getting there. I don't know what Reality uses as default settings when using hybrid, but it just never worked out for me. Fireflies be gone!
Does Luxus support DOF? I'm sure the question has been asked already, but I haven't been able to find the answer. That's a little something I'm missing from Reality 2 right now.
I'm also finding that Lux is closing down on me unexpectedly. A few times I've come back to check progress from an extended absence and found Lux had decided to close. Just did it right then actually! :( Is this happening to anyone else?
I know this image still has quite a bit of noise, but compared to my previous experiences with hybrid I'm very happy. Hmm... just lost my last image. Must have forgotten to take it out of temp (bad idea to default to there in my opinion). This one is kinda close anyway - slightly more noise.
EDIT: not sure what is going on here, but the uploaded image is far brighter than it is on my pc. Sigh everything goes crazy at once.
EDIT 2: Now a little dark XD. It'll do.
Reality supports DOF as far as I know
Yeah, I know. Said as much in my post :D
I've got a textfile where I am saving stuff said in the Luxus threads ... so not my wisdom, just accumulated ...
About Hybrid:
I hope this helps.
Running fine here on 4.5.1.6
I finally got a chance to really give Luxus ago... and here are the results.
