Carrara Non Photo Realistic Works
12728303233100
  • Bunyip02Bunyip02 Posts: 9,291
    Thanks Headwax and UB. I am playing around with combinations of FotoSketcher and Filter Forge - can get some nice results.
    edited September 2017
    Continuing the Ancient Egypt theme.
    1200 x 900 - 3M
    Post edited by Bunyip02 on
    Anubis
    1200 x 900 - 3M
    Mistys Janette G3F with RawArt Lekullion G3F morph and V4 Coral Snake skin.
    1200 x 900 - 3M
    Siesta time
    1200 x 900 - 3M
    Steps to ponder
    1200 x 900 - 3M
  • DiomedeDiomede Posts: 15,401
    Really enjoying your renders, Bunyip.  I have a question about Siesta Time.   Are both Fotosketcher and Filter Forge both part of the workflow for that image?  Or just one or the other?
  • VyusurVyusur Posts: 2,235
    Nice renders, Bunyip02! What the beautiful place is on your last picture?
    Ditto, same question. smiley
    Playing with Filter Forge.
    1500 x 1500 - 5M
    Post edited by Vyusur on
    Hello Diomede and UB
    Base of the picture in PSP was FotoSketcher using the Pencil sketch 4 filter, then a Filter Forge - Old Book Illustrator filter image was overlaid with transperancy adjusted to about 45%.
    Glad you are enjoying the renders as I am having fun experimenting with the different effects.
    Regards, Bunyip
    Hello Vyusur
    Its Stonemason's The Path to Cloud Temple - https://www.daz3d.com/the-path-to-cloud-temple
    Your render is great as well.
    Regards, Bunyip
  • HeadwaxHeadwax Posts: 10,458
    THIS ISNT MINE, I FOUND IT IN ANOTHER THREAD BY De3AN and thought it was worthwhile pointing out
    mindsong said:
    brilliant image! I love the style/result!
    bravo!
    ms
    Thanks! I found the style difficult to achieve.
    head wax said:
    de3an nice work , great to see people taking this approach,
    Thanks Andrew. I saw some similar work recently and thought I'd give it a try.
    Lotharen said:
    This is really cool. How did you achieve that effect?
    DUDU said:
    DE2AN, really cool and interresting render, what's the process ?
    Well, I was afraid someone was going to ask that. frownwink
    I tried lots of settings before I found some that gave me the results I was looking for. It doesn't always produce good results with all subject matter. The best I can do is list the settings that produced this particular result. You could use them as a starting point for your own experiments.
    The character is the original Poser version of “the Girl”.
    Replace all shaders (except the eyes) with almost-black.
    Make two renders; Photorealistic, and NPR.
    Photorealistic settings:
    Remove the default light.
    Set scene Ambient light to 450%
    Set background color to white.
    Set Indirect Light to 142%
    Set Occlusion Radius to 20ft.
    NPR settings:
    Choose only “Outline”.
    Thickness=10%
    Length=208%
    Combine the two renders in Photoshop layers with the Multiply option.
    See the attached settings images:
    Quote
    652 x 459 - 98K
    238 x 167 - 20K
    235 x 286 - 35K
    238 x 286 - 33K
    Using same process as de3an, except I left the shaders as normal.
    good stuff and quick as a flash!!!
    I'll try and have a play with that on the morrow - been working full time which sucks
    edited November 2017
    Here's that same method but with ordinary textures and the lighting settings tweaked. I also added a garoud render and made it b and w-  Plus fotosketcher of course ;)
    975 x 1370 - 722K
    Post edited by Headwax on
    Hya Veronica, as I said in the other thread - that works really well. The textures are just right.
    Thank you once again, Andrew!
    Headwax the combination looks like a great effect.
    Snow Dragon & Snow Elf.
    1200 x 900 - 3M
    Bunyip02 said:
    Hello Vyusur
    Regards, Bunyip
    Thank you, Bunyip
    BTW, nice crisp style on ice dragon picture.
    Excellent work, folks.  I was just playing with the Horse2.  I created a mane and tail with dynamic hair.  I then used the volume pass to combine the hair from the photoreal render with toon and npr renders, and took the result to filter forge.
    1000 x 1333 - 1M
    Post edited by Diomede on
  • That is pretty extraordinary, Diomede!  Nice composition, and a winning combination of filters.
    +1 yes
    Fantasia
    1200 x 900 - 3M
  • PhilWPhilW Posts: 5,162
    Beautiful character and great painted effect!
    Vyusur said:
    Bunyip02 said:
    Hello Vyusur
    Regards, Bunyip
    Thank you, Bunyip
    Thanks Vyusur
    Thanks Phil
    really interesting effect - like an underinked woodcut block - would never guess it was digital
    the mountains in this are double wow. Reminds me of some of Maxfield Parrish's work.
