Daz Versions 4.9.3.166 vs 4.9.4.117
ArtAngel
Recently in August, I installed 2nd latest (mandetory upgrade) DIM version, 4.9.4.117 and content to a clean machine on an internal hard drivea handful of items were intalled with the newest version (mandetory upgrade) of DIM. I had 37 items missing both the thumbnails and file flags on newer items for G3 such as one character from the Olympia 7 Pro Bundle. The lost and found had a total of 234 items including the 37. On a different machine I have 4.9.3.166, a manual install, with only 8 items installed on an external hard drive without the CMS. I just made a backup, ugraded to newest version of DIM and installed all content via DIM including CMS just to see if Stusio was the culprit or DIM. I have 31 missing thumbnails but no flags. and lost and found has 33 items with thumbnails. For me 4.9.3.166 is the winner. This does not seem to be DIM related but Studio related.
I doubt missing meta data would cause those type of issues (ie figures/props loaded as grey blocks). Issues with metadata normally means you can not find a product in the Smart Content tab, grey boxes on the other hand almost always indicate that DS has not located the geometry of one or more of the items. Perhaps you uninstalled something since the last time you loaded up the old scene?
I would not have thought their removal would be the reasons for the problems. The only other thing I can think of is that the paths to the assets in the older format are not being interpreted correctly, although in theory DS should be able to read in older formats (well at least anything saved in DS4.5 or later)
And I've updated to the release version every time since 4.5 and not had content issues w/>3000 items installed.
So?
It is possible for the database to get messed up if you start Studio up too quickly after closing DIM but your actual content will still be intact, so Content Library pane will work but Smart Content pane will not.
I added an old fish to my full cart, checked out, downloaded and installed with DIM (have never used connect) and one of the installs was an updated Install Filter. I attached jpgs in case someone can spot a rhyme or reason to this or add their thoughts. The last 3 digits of each jpg represents the last 3 digits in the Daz Studio version.
Content Library pane, not Smart Content or Products or Categories, if everything is fine their than it is a database/CMS problem.
