shader like this??
ssweete
i just love this by fabina, is there a shader like this?
see thru black with glitter?
ssweete
Very similar
http://www.daz3d.com/shop/sparkles-for-studio/
Its not too hard to build similar shaders. This might be a starting point, sorry for the blur there is a 800pix limit at the moment.
The Clamp brick will set how much sparkles you get.
The first mix will set the opacity
The second mix the colour.
You can also let the clamp output control specular and bump.
And give other sources than random a try.
Cheers! Oom
Any suggestions for reducing the amount of white in the network...
First is with a granite brick added(just an experiment
Second is your network with clamp or step increased to 2.5
