shader like this??
ssweetessweete Posts: 115
i just love this by fabina, is there a shader like this?
see thru black with glitter?
409 x 746 - 50K
  • scorpioscorpio Posts: 8,533
  • Oom FooyatOom Fooyat Posts: 0
    edited June 2012
    Its not too hard to build similar shaders. This might be a starting point, sorry for the blur there is a 800pix limit at the moment.
    The Clamp brick will set how much sparkles you get.
    The first mix will set the opacity
    The second mix the colour.
    You can also let the clamp output control specular and bump.
    And give other sources than random a try.
    Cheers! Oom
    800 x 463 - 96K
    Post edited by Oom Fooyat on
    Cheers! Oom
    Thanks for the network Oom...
    edited June 2012
    Any suggestions for reducing the amount of white in the network...
    First is with a granite brick added(just an experiment
    Second is your network with clamp or step increased to 2.5
    1000 x 1000 - 452K
    1000 x 1000 - 218K
    Post edited by Pendraia on
