Genesis 3 male textures on genesis 8 male
Xyetzt
Is there a way to put Genesis 3 male textures on Genesis 8?
Xyetzt
I was having major problems with the textures but I have done a reformat of Netbook to see if that will help. I am trying to reinstall the stuff now.
Genesis 8 male render problem.
Hmm. Which render engine are you using (3Delight or Iray) and have you loaded the matching material setting?
3Delight as I cannot use iRay. I thought I did use 3Delight files.
Maybe you have run into the AoA Subsurface Shader problem? Is the skin using that shader? There's a long-standing problem where it gets "lost" every so often. Restarting DAZ Studio should fix it, or loading a different skin then the one you want may work. There's another fix wher you clear out a library somewhere, but I can't remember exactly what - I'lll try and track down the forum thread.
Here's the link: https://www.daz3d.com/forums/discussion/comment/874943/#Comment_874943
