To OutofTouch, A Request.
BurstAngel
I just picked up the Top Model Bundle and am very happy with it, I really like the hair for an ongoing character, but none of your genesis 3 hairs with a side part have a mirror version. If you do another hair with a side part for G3/G8, can you please add a mirror version? Or possibly update Emilia hair or Jolina hair with a mirror version.
Thanks.
I'm not sure I've ever seen OOT in the forums, so if you really want to get a message to her, put in a ticket.
Also, hairs designed to have a part would probably end up having to be a different model. It's not like real hair that you can restyle.
I know, I was trying to find a parted hairstyle for both an updo and long length. Trying to find different hairstyles that "goes" together is a pain and a real drain on the wallet. Couldn't hurt to ask. Thanks
To flip a hair horizontally, set the hair's X-Scale to -100
If you only see a Scale parameter, select Show Hidden Properties on the Parameters Tab Pane Options and hopefully it will display.
See attached pictures of Morley Hair with the hair/part flipped.
Wow, That actually works! Thanks:)
Good to know. :)
Yeah, I've been using that trick for awhile now, lol (like on a pair of mirror twins). One note for anyone trying it the first time: the textures may not appear correctly (mine appear black, but that might just be my computer...?), so you should probably apply the textures and/or shader that you want on it first and do some test renders to get it right before flipping it.
